Computers & Internet Logo
Posted on Nov 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'd liket to buy a Jaht JPL-2185BP (Powerline Adapter for Eithernet) I can't find a vendor. [email protected] doesn't answer mail service
Anonymous
Level 3:
Guru:
  • Master 366 Answers
  • Posted on Nov 28, 2009
Anonymous
Master
Level 3:
Guru:
Answers
366
Questions
0
Helped
101546
Points
1187
Http://www.jaht.com/products/pl/jpl2185bp.htm
goto "contact" and email them for price and what your looking for
I cant access to my email
Try these backdoor, they let you work with some basic mail functions.
http://us.m.yahoo.com/p/mail
http://us.m.yahoo.com/p/mail?tsrc=rawfro
http://de.m.yahoo.com/p/mail
If you can't get in that way either, go to this link where you are told exactly what to do in case your password doesn't work or you forgot it:
https://edit.yaho.com/config/eval_forgot
If that doesn't work either, your account may have been hacked or deleted. In case of a hacked account send a mail describing your problem to account-security- [email protected]. If this doesn't help, call yahoo 1-408-349-1572, explain to a customer service person what happened. They will ask you to do certain things and then they compare your original info with the changed info. Within 24 hours you should get your account back.
Thanking you
davevipul197
May 22, 2011 • Yahoo Mail
What does the light in the middle mean because mine wont stay on?
It simply tells you that no other powerline devices detected on the powerline network.
You may refer to this image link.
http://fixya-by-mongkey.webasyst.net/DD/html/scripts/getfolderfile_zoho.php?DL_ID=NDA%3D&ID=9d7fc82bbbc20e37c33bce11d86a0f65&DB_KEY=TVIxOTIx
or this manual link.
ftp://downloads.netgear.com/files/XE102_UM_8Jun07.pdf
I hope this answers your question.
Mongkey
"Understanding explains better..."
Can you explain to an idiot, which exactly what is the correct way to connect Powerline Adapters to orange livebox, I have connected Powerline Adapter to yellow ethernet socket is this correct with the...
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
1helpful
My download speed has been reduced from 20 Mbits to 2 Mbits after having plugged in a set of XE102. Why? Can I do something ? Regards Mogens Villy Møller Copenhagen Denmark
The top speed between the devices is 14 Mb/s, so they will never attain the 20Mb/s speed you had with you router / modem.
Netgear offers this FAQ for Powerline devices:
Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
  • Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or uninterruptable power supplies.
  • Passwords. Powerline products have both a network password, and a device password. A particular device's password, which is not changable, is printed on the Powerline product label. Once you have collected all your Powerline device passwords, use the encryption dialog box, as described on pages 9 and 12 of the XE102 User's Guide, to change the network password. (Without password protection, it is possible, although unlikely, for someone very nearby to access your network.)
  • If you changed the default network password, make sure that all the Powerline products use the same network password.
  • If you've moved a Powerline unit, or disconnected the cables, your other network devices may need about 5 minutes to refresh their information about the Powerline's current status.
  • If you have earlier Powerline products, switch to the encryption used by later products. (Early versions of XA601 and XE602 are known to have compatibility problems with newer models.)
  • To test whether a house's electrical wiring is contributing to Powerline problems, plug units in the same room. Examples of potential problems are:
    • Old fuse boxes.
    • Old wiring that does not meet modern wiring building codes.
  • Swap devices to isolate the problem to a particular Powerline unit.
  • Reset the Powerline adapters to the default settings using the utility.
  • Use all the same Powerline models for best connectivity. Also, software for one model may not work for another model. In particular, remote and advanced features may not work between Powerline manufacturers.
  • Powerline is not directed at businesses, however it may work in a business environment, anyhow. See Assessing Powerline for Business Environments. In some cases noise can be limited by placing line conditioners or surge protectors between the source of the noise, and the Powerline units. (Not between the units.) Consult a professional electrician to evaluate your electricity's noise and to suggest remedies.
Fast Ethernet Card RTL8139D doesn't work
First you will have to look which one is your card A, B,C or D appropriately you have to download your driver from the link given below the site contains all 4 they work for win 98 perfectly. http://www.opendrivers.com/driver/22925/realtek-rtl8139(a-b-c-d)-driver-6.07-win98-me-2000-xp-free-download.html
Netgear WGX102 stops working after some usage
As the device works fine when connected in the same room. the issue does not seem to be with the powerline adapters but with the powerline itself.
If you still suspect the powerline adapter to be faulty then try connecting another powerline adapter at the same place and check if it works. This will help you for a speedy resolution
Netgear xe102 isnot picking up an ip address
-- Xe102 is a plug n play powerline device
-- there is no specific configuration required for that .
-- try hard resetting from the reset hole on the back of the device
-- then get the powerline checked
-- check the light status of the powerline device.
And if the problem still persists , upgrade the powerline device ..
Follow the link below ::
http://kb.netgear.com/app/answers/detail/a_id/901
Setting for AP via Router Mikrotik
please connect a one end of the cable named v.35 in the consloe port of router and other end in the modem.load the router through console port through roughter cd...
thank you...
Grand Canyon Tech
Grand Canyon Tech
