Question about HP Color LaserJet 2600n Printer
HP 2605dn laser printer color problems
When I print from my signlab software it changes all the blues to brown and browns to blues! This only happens with photographs and not vector images and it only happens in this software. This is about the 4th printer I've had with this software and it has always been OK before. For some reason this printer does not pick up the correct cols from the programme.
Please help??
  • Anonymous May 07, 2008
    just the black color is not regeter on the the other color
  • Anonymous May 08, 2008
    color not center
  • 233 Answers
Take a look at these 2 support solutions
solution 1
solution 2
thanks for rating
Posted on Jan 10, 2008
Gray color prints as brown using Photoshop CS6
check your image mode.. click image, then mode, then cmyk color.
Sep 23, 2017 | Epson Stylus Office T1100
Hp color laser jet 2605dn gives me a message printing document but does not continue print it then tels me to turn of printer and turn it back on
According to your problem, The instruction is correct.First remove all pending print job from print queue by double click on printer in printers and faxes wizard. Then reboot the printer and system both. After turn on give a print job. If it doesn't help you then check the page setup in printer properties.
Apr 28, 2011 | HP LaserJet 2605dn Printer
My Hp Color laserjet 2605 was not working some colors (yellow,megeanta) so how to resolve this problem ? all color tones are new ! i would pinted test page black and cyan was ok
This is a common problem with this model of printer. The scanner optic degeneration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta and yellow toner cartridges, red tones are the first to show fading. Colors shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a compliant technician to resolve this issue as it means dismantling your printer and cleaning the mirrors and lenses in the optic section to fix the problem.
Aug 09, 2010 | HP Color LaserJet 2600n Printer
Color in printed pictures is terrible! All HP
try going into your printers properties and look for a print quality tab. One of the tabs will allow you to change your print style on pictures. Or the HP software that came with the printer should allow you to modify the print quality.
Jul 06, 2010 | HP Photosmart 3210 Printer
The right side of the page does not print - HP 2605DN
Most likely the cartridges are out of toner. Or something is obscuring the path of the laser writer. If changing the cartridges does not solve the problem the machine will need servicing. Service manuals are available but not as comprehensive as necessary to fix this problem. Below is a very good DIY guide, but be very careful if you choose to do this yourself and follow his directions precisely.
http://www.reeves-hall.net/tech-gadgets/fixing-washed-out-colour-on-hp-color-laserjet-2605/
Jun 08, 2010 | HP LaserJet 2605dn Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
Have no manual, How do I print 2 sided and in color - HP Color Laser Jet 2605dn
Download the manuals you want from
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=1140727
Feb 27, 2010 | HP LaserJet 2605dn Printer
HP 2605dn laser - color fading
HP has a list of troubleshooting steps you can go through for the HP 2605dn when you experience print quality issues.
Two specific things I would try from that list are:
  1. Clean the electrostatic transfer belt.
  2. Clean the printer paper path.
Good Luck!
*If you find the solution helpful, please rate it!*
May 15, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
735 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
