Question about GE PSS26SHRSS Side by Side Refrigerator
The side by side refrigerator does not have a ice maker or water dispenser. The refer is fairly older but it is a G.E and it is not cooling or freezing at all. Can you help me trouble shoot what could be the cause?
  • Mike Smith
    Mike Smith May 11, 2010
    I would need your complete model number , also , do you see frost on the inside rear freezer wall ? Do you hear a " clicking " comming from the back of the refrig ? Are your coils at the bottom , clean of dust , lint , etc ? Is the fan which cools the compressor , behind the refrig running ? Is the compressor running ?
    President:
  • GE Master
  • 1,922 Answers
You will need to replace G.E.part# AP4297272 main control board in the lower right rear of refrige, it can be changed from the outside thru a panel
Posted on Nov 19, 2009
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Admiral Maytag side by side model LSD2615HEW not getting cold. Fan runs. Clicks from the back every few minutes or so.
Its issue with compressor or the problem with defrost timer.It clicking to set the defrost cycle,but not actually working.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 26, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice dispenser grill
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 24, 2012 | GE Profile PSW26P Stainless Steel Side by...
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
Clicking sound from back of fridge
Its faulty capacitor or compressor relay or the timer.Its in the lower end back.
These will help.
Thanks,.
Dec 22, 2012 | Hotpoint HSS25GFP Side by Side...
My Samsung RS2556BB refrigerator ice maker is not making ice anymore. The freezer still very cold but there is no water coming into the ice tray. I switched the relay in the back and pressed the water...
These will help.
Thanks,.
Dec 22, 2012 | Samsung RS2556 Side by Side Refrigerator
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Warm water is coming out of new refrigator water
Is there a coil of tubing inside the refrigerator? This is how they usually cool the water. If you use a lot of water through the dispenser, the water will become warm.
I hope that this helps.
Tim
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker Kenmore Side by side
You have two separate solenoids to your ice and water. One controls the water the other the ice maker. Check the ice maker solenoid and see if it is getting 110v to it and is opening. You will find it in back of the refer under the cardboard panel. Just follow the hoses.
Dec 18, 2007 | Kenmore 44109 / 44102 Side by Side...
GE PSS26SHRSS Side by Side Refrigerator Logo
87 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
