SOURCE: Panasonic cordless phone,
I have lost the insruction manual for my cordless panasonic phone model KX-TGA542S and do not know how to turn on the ringer again. My menu states "ringer off" so how do I turn it back on?
SOURCE: The ringer on my phone
Press MENU followed by # then dial 160 then press (1 for low volume) (2 for medium volume) or (3 for high volume) then press OFF. if you press 0 that turns off the ringer.
SOURCE: The ringer is turned off on my Panasonic cordless phone.
you go to profiles and select customize and then you can select the ring on or off for the incoming calls,msg....
SOURCE: My Panasonic kx tg-2620 shows "ringer off". How do I turn it on?
To solve it, I pressed Menu then the silver down arrow to access the Ringer Settings. For some reason, I was trying to use the black buttons beside the Menu button to navigate.
Thanks anyway!
SOURCE: how do I turn off
Note, in these instructions:
{V} = down on Navigator key (large key in center of phone)
{^} = up on Navigator key
{>} = right on Navigator key
4 volume levels (high/medium/low/off) are available. The default setting is HIGH.
1 .Press {MENU}.
2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}.
3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}.
4 Press {V} or {^} repeatedly to select the desired volume.
To turn the ringer off, press {V} repeatedly until "Off ?" is displayed.
5' Press {Save}.
Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
What's the model of the phone? Does it display RING OFF or did you turn it off on the side? What happens if you swap the phone with another? Does the instrument not ring, or is it the extension?
