Compaq cq60-419wm - my dvd/cd drive is not working, not even recognized as being there by the computer (not listed as a drive available under My Computer)
    Novelist:
  • 210 Answers
If it's not recognised, look for a little latch on the underside of the laptop that releases the drive completely. If you can manage to slide the whole unit out, push it back in firmly until the latch clicks into the locked position again. Power the laptop up and try again.
Posted on Nov 18, 2009
Compaq Presario F761 Won't recognize DVD RW Drive
First try to load the drivers for the system. Go to dell website provide the service tag and try to install the drivers. If this does not work then take the back up of data and do a simple factory restore.Check out my blog Click here
Kindly click skip ad in the top right hand side to view the article
Nov 27, 2011 | Compaq Presario PCCOM2232US Notebook
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
HP Compaq DC7900 CD/DVD problem - computer does not read them
I guess the CD/DVD drive is not detected in my computer
Then you can follow the following steps:
CAUSE-It may happen due to some corrupted registry keys in the computer. We can follow the following steps to delete the upper and the lower filters.
RESOLUTION/ WORKAROUND-
1. Locate the following key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet
2. In some cases, there may be multiple ControlSets. You may see something similar to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
Or
3. Select either CurrentControl Set or the lowest numbered ControlSet, for example, in the second list above, ControlSet001, and do the following.
4. Locate the following key and highlight it in the left window of the Registry Editor. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5. In the right window, you should see something similar to the list below. There may be some variation in the listed drivers for the upper and lower filters. For example, the upper filters may list a driver other that PWD_2K. You may also see only upper or only lower filters:
LowerFilters = CDRALW2K
UpperFilters = PWD_2K
6. Delete the upper and/or lower filters.
7. Exit the Registry Editor and restart the system.
NOTE: If the computer still does not recognize the drives, go back into the registry and repeat the above steps for editing the registry for each of the ControlSets listed on the system.
Hope it works for u
All The Best !!!!
May 09, 2010 | HP Compaq DC7900 PC Desktop
Doesn`t work all the time and makes a whirring noise, do i need to buy a new cd/dvd drive?
Before you beginTo determine if the CD or DVD drive displays on the My Computer screen, follow the steps below.
  1. Turn on the computer and remove any discs from the CD/DVD drive.
  2. In Windows 98 and Me, double-click the My Computer icon on the desktop. In Windows XP, click Start and then My Computer .
  3. A CD/DVD drive icon displays on the My Computer screen when Windows recognizes the drive. If Windows recognizes the drive, find and use a section below that pertains to the CD-writing software with the issue.
  4. If the drive does not display on the My Computer screen, go to the Microsoft support website and search for documents on missing CD DVD drive .
RecordNow by Veritas/HP/Sonic does not recognize the CDRW or DVD+RW driveIf RecordNow does not recognize the CDRW or DVD+RW drive, follow the steps below.
NOTE: Install any updates for the RecordNow engine available on the Sonic support web site (in English). Step 1: Uninstalling RecordNowTo uninstall RecordNow to reset the software and cause it to look for the CDRW or DVD+RW drive again, follow the steps below.
NOTE: The steps below pertain to Windows XP.
  1. Click Start and then Control Panel .
  2. Double-click Add or Remove Programs .
  3. Select Record Now and then click Add/Remove .
  4. Follow the on-screen instructions until the uninstaller finishes.
  5. Select DirectCD and then click Add/Remove .
  6. Follow the on-screen instructions until the uninstaller finishes.
  7. Remove any discs from the drives and restart the computer.
Step 2: Installing RecordNow using Application RecoveryAfter Windows restarts, install the RecordNow software to begin creating CDs.To install the RecordNow software, follow the steps below.
  1. Click Start , All Programs , HP Tools or Compaq Tools , and then Application Recovery .
  2. Click Application Installation and then click Next .
  3. Select HP Record Now or Sonic RecordNow! and then click Install .
  4. The installation automatically installs all files. Follow the on-screen instructions.
  5. Restart the computer after the installation completes.
The HP Record Now or Sonic RecordNow! software should now recognize the CDRW drive. Back to topRoxio (Adaptec's) Easy CD Creator does not detect the CDRW driveEasy CD Creator produces an error message when it is unable to detect the drive, such as: There are currently no supported CD Recorders available...To prevent these errors from occurring, follow the steps below.
NOTE: Windows XP is not compatible with Easy CD Creator 4 and earlier. If the HP Pavilion computer was updated to Windows XP from Windows 98 or Me, use the native CD writing ability in Windows XP or purchase and install CD writing software that is compatible. Step 1: Installing updates for Roxio (Adaptec) Recording Software If the recording software is from Roxio (formerly Adaptec), go to the Roxio software updates page (in English) to obtain any software updates that are available for Easy CD Creator (with or without CD Copier or Direct CD). If Roxio still does not detect the CDRW drive after installing the updates, continue to the next step. Step 2: Changing the CD drive letter back, if it changedUpgrading to Windows 98 or Windows Me can change the drive letter to a different letter and make the drive undetectable to Easy CD Creator. To change the drive letter back to F or another previously designated letter, follow the steps below.
  1. Right-click the My Computer icon on the desktop.
  2. Click Properties . The System Properties window opens.
  3. Click the Device Manager tab.
  4. Click the plus sign next to CD-ROM .
  5. Double-click the CD-ROM name and then click the Settings tab.
  6. Under Reserved drive letters , select M (or the previously assigned letter) from the drop-down list. Be sure that both the Start drive letter and the End drive letter are the same.
  7. Click OK , Close , and then Yes .
  8. Restart the computer. If Easy CD Creator continues to fail to recognize the CDRW drive, continue to the next step.
Step 3: Uninstalling Easy CD CreatorIf the above steps fail to make Easy CD Creator recognize the CDRW, recover Easy CD Creator by uninstalling it. Recovering Easy CD Creator resets the software and causes it to look for the CDRW drive again. Be sure that you have the last recovery disc of your Pavilion recovery disc set before continuing.uninstall Easy CD Creator, Step 4: Installing Easy CD Creator using Application Recovery
Jan 17, 2010 | HP Pavilion dv6000z Notebook
The DVD drive in my wife's Compaq Evo N600C has stopped reading CDs. It reads DVDs fine, but doesn't recognize any CD or CD-R.
1. Right-Click on My Computer -> Properties
2. Click on Device Manager.
3. In the list of devices, click on CD/DVD Drives.
4. Select ur CD/DVD device and right-click on it.
5. Check the Device Status (Working Properly)!
6. If required, You can update / uninstall / rollback the driver for this device by clicking on, Driver option.
7. Apply settings and close dialog box.
8. Restart the system.
if it helps tell me....tc! :)
Jan 03, 2010 | HP Compaq Evo Notebook N600c
CD drive not recognized error code 0F00.281A
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program
Click Start, click My Computer, and then see whether the drive is listed.
Is the drive listed? loadTOCNode(2, 'moreinformation');
If the drive is listed, try to play or access a CD or DVD.
If you can play or access a CD or DVD, you are finished with this article.
If you cannot play or access a CD or DVD, you may have to reinstall some programs. Some programs might not be able to use your CD or DVD drive until you reinstall those programs. If the problem occurs again when you install or uninstall those programs, contact the manufacturer of the program to see if an update is available that solves the problem. Some examples of programs that might be affected are:
  • iTunes software by Apple
  • Nero software by Nero Inc
  • Roxio Creator software by Sonic Solutions
  • Zune software by Microsoft
After reinstalling your programs, if you can play or access a CD or DVD, you are finished with this article.
If you still cannot play or access a CD or DVD,
If the drive is not listed, remove and reinstall the existing drivers.
Nov 12, 2009 | Dell Precision T3400 375W 32bit Computer...
Dvd rom doesn't work
try to clean the dvd rom drive by a lens cleaner...
May 27, 2009 | Computers & Internet
Compaq V2000 - Service Tag V2220US Only recognizes the CD/DVD drive as "CD" Does not see it as a DVD Drive. Listed as: _NEC DVD+-RW ND-6500A in Device Manager.
Try updating your drivers from www.hp.com
If the issue is that it won't play DVD movies only then you probably need to install or re-install the DVD player software that should have come with your computer. If you don't have it anymore, simply download from HP.
Apr 24, 2009 | Computers & Internet
DVD doesn't open
This problem may be a bad cd/dvd drive. When the computer boots up, go into the BIOS setup. Check to see if the computer recognizes the drive, and make sure it is not disabled. Next, check in the "device manager" to see if there are any yellow question marks or red X's. This might indicate a driver problem, or a misconfigured drive. If these steps fail to resolve your problem, replacing the drive would be your next step. This is a fairly easy task, and worth the time to research the steps for your particular model.
Nov 15, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
