Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Flash has stopped working on my Nikon D40. I've tried a factory reset, tried to get to the flash setting but that menu option is no longer available (highlighted) in any mode. I'm thinking it's broken and not a setting thing. Everything else works fine and it still takes pictures just without the flash. The flash pops up when needed but no flash obviously.
  • 4 Answers
There's a common problem in the flash arm. I found this link that shows a simple repair. If you use this and make the repair yourself, understand that you will void your warranty if you have one. Also, do not touch the bulb as you'll get oil on it, and don't touch the solder points on the wiring, you'll get zapped. http://www.vimeo.com/3141400
Posted on Nov 22, 2009
    Brigadier General:
  • 11,967 Answers
Either the flash tube is burned out or you've lost the connection to the flash.Either way, you need service.
Posted on Nov 18, 2009
Flash on Nikon D40 not working
turn it on go to menu custom setting menu then braketing /flash then toggle right and turn it on
Nov 03, 2013 | Nikon D40 Digital Camera
Nikon d40 flash won't fire
If it clicks when the flash is already open, it seems there would be a problem with the flash open sensor. The camera thinks the flash is closed, so it tries to open it again and it refuses to fire, because firing in the closed position would blow the bulb.
The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
(And DON'T fire the flash when open, or at the very least don't touch anything in there when firing or you'll get zapped.
Goodluck..
May 16, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 is taking Dark Pictures. Flash is
kindly see the aparture and speed of xpouser and the iso also if the iso is 100 change the iso to 400 or 800 or u can select he programme option for the best xpousers
Nov 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Internal flash not firing on nikon d40
Make sure you have read your user manual and know how to use the camera, including how to use the flash.
Go to the menus set all settings to factory settings. Later you can set them the way you want. Make sure all settings are set to make the flash work when you want to use it. Some settings will turn off the flash.
If you need technical support or repair consider calling Nikon. Go to nikon.com and browse to the support section, find the repair and the toll free number. Call and see if you can get help on your camera.
Nikon has an up-grade or trade-in program for refurbished units if your repair is too expensive.
Oct 22, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Hi there, my Nikon D40x flash suddenly stopped working (popping up but not flashing) after I was fooling around with the manual settings, now no matter what I do the "no flash" icon appears beside the...
Try turning camera on,
Then press both Green buttons for a count of 10. This should restore factory reset.
Some models also have a reset button under a connector flap, or go into your menu. Under Custom Setting Menu, choose Menu Reset.
One of these methods should work.
Sep 22, 2009 | Nikon D40x Digital Camera
The flash on my camera
There is no top LCD on the D40. Put the camera in AUTO mode (green icon on the dial) and take a picture in the shade. if the flash does not go o, then you have a fault. Send back to authorized repair centre.
Dec 09, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon coolpix 774 menu buttons don't work
Try resetting the camera back to the factory default setting.
Remove the battery, leave it for 1/2 + hour, insert the battery and configure date time etc.
If it doesn't work then you have faulty camera.
Dec 03, 2008 | Nikon Coolpix 775 Digital Camera
Problem with the Flash Light of Nikon COOLPIX L12 Digital Camera
I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Cheers.
Sep 27, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon D40 will not flash
The lightning bolt icon in viewfinder blinks when flash is not ready, this can happen if flash doesnt pop up all the way, or if flash strobe tube is bad.
If lightning bolt icon is blinking in viewfinder, flash is not ready. Either flash isnt popped up all the way or flash strobe tube is bad.
May 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
265 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
