Question about Copystar CS-2550 All-In-One Printer
Copystar cs-2550 service code c6000 - Copystar CS-2550 All-In-One Printer
  • 622 Answers
Bad fuser... replace it...
Posted on Dec 26, 2009
Cant copy cod c 6000
call for service diye uyar? veriyor nedeni nedir yard?mc? olabilirmisiniz?
Jan 23, 2010 | Copystar CS-2550 All-In-One Printer
Cs-2550 sofware
goto usa.copystar.com and search in downloads...
Nov 20, 2009 | Copystar CS-2550 All-In-One Printer
Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
The password is 6482, this is the admin password for all copystar machines.
Thanks for using Fixya
May 20, 2009 | Copystar CS-2550 All-In-One Printer
try this. enter "10871087" from keypad. you should now be in maintenance mode. enter "163"press "start or print" key. you should see a screen that says "execute" or it may say "reset". cursor or highlight "execute" and press "start" key. now press "stop/clear" once or twice. then press "01" then "start" to exit maint. mode. very important!! as soon as you press "01" and you see "please wait" open your front door. wait 2 secs, then close door. that should get you going unless there is a true failure. good luck and you may want to write this procedure down as it may happen sometime again.
hth,
razors
Mar 30, 2009 | Copystar CS-2550 All-In-One Printer
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Copystar cs1815 c6000 code
This is a fuser problem -- here is a reset method:
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Aug 18, 2008 | Copystar CS-1815 Printer
Copystar CS-2550 All-In-One Printer Logo
134 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
