Question about Ricoh Aficio 2015 Copier
Error code I ve got Ricoh aficio 2016. after 5 pages of copy, the display shows error code sc:390. What should i do?
  • Nasir Hussain May 28, 2013
    td sensor error & toner overfull u shud open the door & remove the toner buttel & some make some copies dark mater whene copy will light use normally
    President:
  • 1,257 Answers
    President:
  • 4,402 Answers
I think you have a bad motor, unplug for and hour and try again, if still get message contact your local authorized service provider.
Posted on Jan 10, 2008
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Code SC 390
SC 390 is a TD sensor code try changing developer (Type 24) B0649645 if not that then maybe the TD sensor pn#B2475310,
Mar 18, 2014 | Ricoh Aficio MP6001 Copier
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Functional problem sc 390 on ricoh photocopier, despite replacing drum, developer,blade,gears. after removing 9 copies it reads functional problem.
SC 390 on an Aficio 1018 will most likely be a bad TD (toner density) sensor, if you've already replaced the drum and developer. (One thing to check quickly though is to pull the PCU out and reinstall it, just to make sure that connection isn't the problem.)
You can either replace the TD sensor by itself, or replace the DV unit (which probably won't be much more expensive). But either way, you'll need to install new developer when you replace the parts.
Aug 17, 2011 | Ricoh Aficio 1018 Printer
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
My aficio richo 2016 black and white copier is showing code error sc 544. pls how do i fix this problem.
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
May 11, 2011 | Ricoh Aficio 2016 Black and White Copier
Sc 390
SC 390 TD sensor error
The TD sensor outputs less than 0.5V
or more than 4.0V 10 times
consecutively during copying.
• TD sensor abnormal
Poor connection of the PCU
Dec 30, 2010 | Ricoh Aficio 2015 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
757 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
