Question about E-Machines eMachines Desktop PC
Emachine starts boot process but stalls, no beeps
Emachine (T1842) starts boot process but stalls, no beeps heard, is this memory issue?
  • 64 Answers
Most likeley if you see something on the screen but it wont boot it is a mem problem, does it load bios, if so it is prob not memory
Posted on Nov 18, 2009
I hear 4 beeps ever 5 minutes on my emachine et1331g
That is somewhat odd. I don't think that I've personally heard of that happening before. Question: What is the date/time on your computer? I ask this as I believe that your issue may have to do with the little battery on the motherboard.
If the date/time on your computer gets reset every time you turn on the machine then you'll want to replace the little battery on the motherboard.
Dec 10, 2012 | E-Machines eMachines Desktop PC
I have a 5 year old Emachines computer, a few weeks ago I bumped my foot on the desk that was holding the computer and the screen turned off and the tower started beeping. It was long continuous beeps. I...
Usually when you hear long beeps coming from your computer it telling you that there is hardware loose . You may have knocked something loose. Check cd roms , ports and cards , memory to make sure they are fitted in correctly . good luck
Aug 03, 2017 | Computers & Internet
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
7/1/11 eMachine T6211 won't boot at all; no fan starting, monitor says there is no connection and there is beeping that does not stop. Short beeps spaced evenly. Could it be bad capacitors? When...
Most probably is a RAM memory issue, those beeps are issued when a RAM module can not be found, may be the machine sufferend a crash an the ram jumped out of it's slot (less probable) or just broke (Most probably) certainly a tecnician can save your data to another PC or even, fix the broken PC by replacing the broken RAM module with a new one
Jul 02, 2011 | eMachines T6211 PC Desktop
After a short while, I get the normal 1 beep indicating (from what I've read on the internet) that the POST checks have been passed. Shortly after that, one of two things happen: 1. When booting for...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
the grrr is the sound its not getting enough power
test your PSU power supply unit or replace it if the fan is not working the PSU is faulty
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 27, 2010 | MSI MS-6380E (MS-6380E-010) Motherboard
I AM TROUBLESHOOTING AN EMACHINE MODEL W3410 AMD ATHLON THAT JUST CONTINUES A LONG REPEATING BEEP AT BOOT AND AM NOT RECIEVING SIGNAL TO MONITOR. IS IT MEMORY OR VIDEO . CAN'T GET A CLEAR TOPIC FOR THE...
Almost always indicative of a RAM memory problem. Troubleshoot by removing 1 stick of memory and rebooting. Switch sticks to determine if either stick of memory is bad or a bad bank on the motherboard.
Nov 23, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
PC wont start/boot
hello...i think you need to check all socket connection on the board and you need to check the memory or try to reset the Bios.or check the ATX power supply it is good or working..thank you
May 08, 2009 | eMachines D3415 PC Desktop
Power and fan run light flicker in front does not boot up
Relace the psu it's a dodgy Bestec ..replace it with a winpower psu 400 watt , they are cheap but they work better.
Mar 28, 2009 | E-Machines T1842 PC Desktop
Short but rapid beep code when powering up emachine
The beep code most likely is either video card or memory.
If you have a video card or can borrow one that you know it works try it first, if that doesn't resolve your issue try the memory.
You can take the memory out and have it tested to see if it is defective.
Go to this site and get the Beep Codes, http://www.computerhope.com/beep.htm
I hope this helps.
Good Luck.
Feb 26, 2009 | E-Machines eMachines Desktop PC
EMACHINE T1842
I had the same issue. I know the problem. Your power source is not working proprietly and you need to change it.
Dec 24, 2008 | E-Machines T1842 PC Desktop
E-Machines eMachines Desktop PC Logo
319 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
