Question about Acer Aspire 5100 Notebook
Usb port dont work
My 2 usb port of acer aspire 3680 dont work. i have check the usb port in the manager it shows device are working properly
    Novelist:
  • 101 Answers
Hi Walum,
Go to the Device Manager, right click on each hub, and select Uninstall. Reboot, and make sure they reinstall.
If Windows don't detect them, go into your bios, and make sure they are enabled. To access the bios, press the Del, F2, or F10 key at bootup. Because there are several different bios's, I can't give you exact steps.
If they are installed ok, download this program.
http://www.nirsoft.net/utils/usb_devices_view.html
Install it. Open it and got to Options and click on "Show Disconneted devices". Click on Edit and Select all. Then click on File and Uninstall Selected devices.
XP remembers each USB device, and if you don't use the option to stop and remove the USB devices, its "memory" gets filled up.
Good Luck!
Posted on Jan 10, 2008
    Scholar:
  • 135 Answers
Do you have a docking station\port replicator? If so, did you undock properly (through windows) prior to disconnecting your laptop from the docking station\port replicator? If not, connect it back to the docking station and undock it properly. Of course, you should also try to restart the computer.
If that's not the problem, your USB ports could be defective. If your laptop is under warranty, you should have no problem getting it serviced.
  • 689 Answers
Usually issue might be BIOS and Chipset related
first of all ensure if your BIOS is up to date, latest released version is Flash BIOS v1.3505, If yours is below this update the BIOS
next step will be updating the Chipset (Intel Chipset driver v8.0.0.1009)
Both of the drivers are available. I am adding the direct link for your convenience. Here is the link;
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=5924616&CFTOKEN=73863150
Please post more if you need further assistance.
Good Luck
My two right hand usb ports won't work
Ist u check the BIOS Setup if the Usb port are enable then u r ports need to repair on shop
http://software1cracks.blogspot.com/
Oct 30, 2013 | Acer Aspire E1-571-6650 Laptop
Acer d257 usb port not working
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
hope this helps
Jul 24, 2012 | Acer Aspire One D257 Netbook
Driver issue (vista) and usb crapped out
Actually, in such situations you should use proper driver disk of those hardware devices... if any disk is not available then please download respective drivers from their manufacturers and then update them... I know vista have such issues... so no need to panic... rate if my help works out for you...
Apr 23, 2009 | Acer Aspire 3680 Laptop
Usb port issues
You could try uninstalling the USB items in Device Manager and allow them to be reinstalled. Also verify USB is enabled in the BIOS.
Dec 06, 2008 | Acer Aspire 5580 Notebook
Acer usb cam makfunctioning
try consulting the mfg for updated drivers. Try removing the usb port it's using and letting it redetect the port, also see if there is special software that comes with the usb camera and reinstall that. If all fails reinstall windows.
Nov 19, 2008 | Acer Aspire 5100 Notebook
Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Jun 01, 2008 | Acer Aspire 3680 Laptop
USB ports not working
Looks like it is a problem with those ports since you bought the computer.
Pls take it to a local tech to diagnose the problem or contact Acer Tech Support
Feb 13, 2008 | Acer Aspire 9503EWSMi Notebook
Help i Have USB problems
try going into Control panel-administrative tools-computer management-disk manager Does it show up there? could be a problem with the memory sticks too: like unformatted state tried in another pc?
Sep 29, 2007 | Acer Aspire 5102WLMi Notebook
Device manager shows the USB port if they are attached to you notebook. And in your case they are attached. So it will show it. Now in your case the problem is in your USB. Get it changed. If it is in warranty peroid then dont u take any risk. Let it be replaced. Or give your notebook in warranty period to the company from which you bought.
Sep 26, 2007 | Acer Aspire 3610 Notebook
USB ports not working Acer Aspire laptop
Two solutions would be to either restore your pc to before the problem started,using system restore on accesories menu, or use the recovery cd or the recovery folder Acer laptops usually have on the 'D' drive and re-install usb controllers and drivers.
Nov 24, 2006 | Acer Aspire 3000 Notebook
Acer Aspire 5100 Notebook Logo
243 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
