The pulley on the front roller is pressed on. Sounds like you pulley has broken free from roller. The front roller needs to be replaced. A quick fix which I've seen last a long time. First verify that this is what your problem is. If it isn't obvious mark roller and pulley, use machine and see if your mark moved. Sounds like yours should pretty easy to tell. If it is indeed lose, mark where pulley sits on the roller. Remove the drive belt. Take a hammer and gently bump pulley to the side. Apply some super glue where pulley normally sits. Bump pulley back into place and let dry. Replace drive belt and check.
