Paper Jaming The printer worked properly the last time I used it. Today the paper jams each time. The right corner jams down and stops...
    Problem Solver:
  • 9 Answers
Theres probably some risiduals at the corner from other papers,, take blow to it
Posted on Nov 17, 2009
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
Hp4200 duplexer paper jam
If it jams every time, remove the duplexer and look for a piece of paper on the metal plate as the paper feeds out of the duplexer and back into the machine. Also use a file folder to push any jammed paper out from inside the duplex module.
Mar 14, 2015 | HP LaserJet 4200 Printer
Dell v313w paper wont stop jaming
something is blocking it like a paperclip or ball of paper...something not easily seen...clean thoroughly
Feb 05, 2012 | Dell V313w AllInOne InkJet Printer
Unable to print 70
  1. Open the Outer Back(Rear) Cover (1) at the back of the machine. Pull the jammed paper out of the machine.
  2. Close the Inner Back(Rear) Cover (1) if it is open as shown in the illustration.
  3. Close the Outer Back(Rear) Cover. Make sure the cover is closed properly.
  4. Pull the paper trays (1) out of the machine.
  5. Push the two green levers up on both sides.
  6. Pull out the jammed paper (1) and press Stop/Exit.
  7. Push the green duplex unit up.
  8. Reset the machine by lifting the scanner cover from the front of the machine and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
  9. Using both hands, use the plastic tabs on both sides of the machine to lift the Scanner Cover (1) into the open position. Make sure that there is no jammed paper left in the corners of the machine under the plastic covers.
    Note
    • If ink gets on your skin or clothing immediately wash it off with soap or detergent.
    • If the paper is jammed under the print head, unplug the machine from the power source, and then move the print head to take out the paper.
    • If the print head has stopped in the right corner as shown in the illustration, you cannot move the print head. Press Stop/Exit until the print head moves to the middle. Then unplug the machine from the power source, and take out the paper.
    1. Gently close the scanner cover using the finger holds on both sides of it as you push down on the Scanner Cover Support (1).
    Caution Be careful not to trap your fingers under the scanner cover. Always use the finger holds provided on both sides of the scanner cover when opening and closing it.
    1. Push paper tray #1 and paper tray #2 firmly back into the machine.
    Note Make sure you pull out the paper support until it clicks.
Nov 11, 2011 | Brother MFC-6890CDW Printer
Non stop papper jam what we do?
My first idea would be to clean the feed roll . I am not sure what more to tell you right now without knowing where it is jaming.
You may also want to confirm that the machine is displaying the proper paper size and proper orientation in the paper tray. Often times if the paper is stopping, without the paper being damaged, the tray settings are incorrect. Look on the machine display and confirm the proper paper size and orientation. Those trays flex a lot and that simply may be your problem.
Feb 19, 2011 | Xerox CopyCentre C118 Copier
Right corner paper jam fixes?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | Canon PIXMA MP460 All-In-One InkJet...
CLP 300 was paper jaming with in first 2 inches, claened rollers and is now jaming in top of machine. have tried changing paper no effect
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Samsung CLP 300 Laser Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Paper keeps jaming
I have the same exact problem -
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Brother printer jams all the time
Be sure the paper tray is not over full and maybe even fan the paper before loading. Check all the corners that hold the paper as they are usually adjustable for different paper sizes and sometimes move or become unattached. The paper must lay flat and snugly in all places in the tray to load properly.
Mar 28, 2007 | Brother MFC 420CN All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
