Question about GIMP GNU Image Manipulation Program
No problem so far just lookin for a tuteral on layers having hard time with this
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GIMP Master
  • 102,366 Answers
Start at http://www.gimp.org/tutorials/
Posted on Feb 19, 2010
Pc doe not uplowld tuteral,moviesm,or dvds.
First questions:Do you have a registered version of the software? What operating system do you use?(version, service pack version)Do you get any errors?What are those errors?
Jan 26, 2012 | Celestron NexRemote Telescope Control...
Schematic of behringer eurolive b215d
Dear Lucastroo, I know what the problem is.
Contact me: mezaejorge@gmail.com
The outputs mosfet poor heat dissipation.
Dec 18, 2010 | Audio Players & Recorders
How do you merge two different pictures into one i have played with the layers but have gotten nowhere, i have several pictures that i want to merge into a final 8X 10 photo
This is difficult to explain in a short time, but there are a few ways to go about it. You can make the top layer transparent to an extent, and you will see the bottom layer through it. You can remove portions of the top layer by deleting areas so that you see what is behind it. Or, you can copy and paste portions of one photo and paste it on top of the other.I don't use Nova, so I can't begin to tell you which tools to use, but photoshop has various selection tools (circles, squares, freehand) that you can use to copy sections, delete, make new layers from, the list goes on. You would be far better off on a forum that specializes in how to for your graphic program. I've had files with so many layers my head would spin and there are sooooo many things you can do, I can't do you justice here.
Nov 15, 2009 | Nova Development Photo Explosion Deluxe...
Where is the dodge tool?
Dodge tool should be on your toolbar- its like a black circle with a little line coming down diagonally from it- shares a button with sponge and burn so may be hidden behind them. Left hold click if it is that should bring up a little drop down that will let you select the tool you need.
Other than that, a much much better way to dodge/burn is to use layers- go to layers (top of the screen beside file, edit, etc)
select new->layer- this should open a box.
Now- set the colour drop down to none
Mode drop down- Set to soft light, feel free to experiment with hard light etc
Tick the soft light neutral colour (50%grey) box- should be at the bottom of the box.
Set opacity to somewhere between 5 and 10 %.
Click OK
This puts a new layer over your image, now you can use the paint brush- set your colours to black and white, you use white to dodge black to burn.
Though this may sound complicated, it soon becomes second nature once your used to it and gives you alot more control of your dodging and burning- leaving you with a much more 'natural' image. Once you get the hang of it you can add new layers (using the same process i went through above) to slowly build up your dodging and burning- changing the opacity level in the layer box to a higher setting means you put more paint on the image- your burning will be darker, dodging lighter.
Using mulitple layers also allows you to take away a dodge layer if you think you have gone to far- and saves you stepping backward when you mess up- its almost like painting.
Oct 21, 2009 | Adobe Photoshop CS for PC
HP Pavillion F1503 screen has gone dark...background is very, very faint, barely able to see/read it. What is the problem? If it is a ''backlight'', then what exact is a backlight, what does it do, is it...
Most of the time in this situation, the problem is due to the backlight going out. However, there are some instances where the inverter cable is bad.
The backlight is the part of the LCD which illuminates the screen. Think of an LCD as having multiple layers. One layer has the image itself on a semi-transparent layer and then behind that layer rests the backlight (usually a florescent bulb) which shines through all other layers to make the image glow and illuminate.
More info can be found here:
http://en.wikipedia.org/wiki/Backlight
As far as replacing the backlight, I always replace the whole LCD itself, which includes the backlight.
Otherwise, you risk ordering the backlight and finding out that it was the connection from the backlight to the LCD that was causing the problem (very possible) and then you would have to order the LCD anyway.
Sep 05, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Photoshop, separating gray shades
I'd select the different levels of gray, and cut the color out of the picture, then paste it into a new document, using the exact same document and canvas sizes each time, so that you end up with three or four new documents, each with a different level of grey. If you're familiar enough with PS, you can do so by adding four new layers, and simply copy and paste the colors to four separate layers, and just hide all layers except the one you're printing currently. PS will ignore all layers that are invisible when printing. Click the 'eye' icon on each layer so that all of them are hidden except the one you want to print.
Hope this will FixYa!!!
Jun 01, 2008 | Adobe FC Photoshop CS V8.0 for mac
Ewf2004 tv problem
I can email the service manual to you if you send me an email to missiontracetv@msn.com.
Feb 10, 2008 | Emerson EWF2004 20" TV
Open Questions:
See all GIMP GNU Image Manipulation Program Questions
GIMP GNU Image Manipulation Program Logo
73 people viewed this question
Top GIMP Computers & Internet Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Alun Cox
ray gallant
Are you a GIMP Computer and Internet Expert? Answer questions, earn points and help others
