Furnance Blows cold air when not on - Heating & Cooling
  • Anonymous Mar 14, 2014
    I have forced air when i turn it on it blows out cold air only
  • 1,420 Answers
Is the thermost set on Auto or Fan. If you want the fan to blow all the time, select Fan setting otherwise select Auto. Then again you could have a stuck fan relay.
Posted on Nov 18, 2009
Furnance comes on but the air stop getting cold just blows air ....what could be the problem
It sounds like it could either be low on refrigerant or the compressor has stopped working. Start by verifying that all the breakers and controls are in the on position. If the outdoor unit is running but you have no cold air, you may need a HVAC company at this point.
Sep 08, 2013 | Ruud UBHC Air Conditioner
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
My furnance (Amana 90) will not work when it's extremely cold outside. I have checked and replaced the flame sensor. I've checked the pressure switch. The furnance is a champ at all times other than...
Since it only does this in extremely cold times is there any chance that your drain line from the condensate drain is passing thru a space cold enough to freeze it. Good luck and thank you.
Feb 23, 2011 | Heating & Cooling
Furnance blows out cold air
Your problem is listed under Air Conditioners--
So is your furnace gas fired, oil fired-- or possibly a Heat pump?
Heat pumps have a hard time getting any heat from outside, when it is bitter cold out-- could that be a clue?
If you have gas-- Does your furnace have a standing pilot?-- if so, when was the Thermocouple last changed?
If it has a glow ignitor-- is the ignitor glowing brightly on start up?
If oil, do you have both oil and spark-- right at the nozzle tip-
Please tell us more, so we can help you more.
Mack B
Jan 23, 2011 | Heating & Cooling
Heil furnance blows out cool air but not heat.
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 04, 2011 | Heating & Cooling
Furnace blows cold air, ignitor won't glow.
ok this is going to sound funny but it seems as though the polarity is reversed going into your furnance. to correct this proiblem you first need to unplug the unit and where the cord goes into the furnance at that connection disconnect the two wires. Once theses are disconnected switch the wires .All you are doing is reversing the way the electricity flows into the circut board. I would wager that is the problem
Apr 13, 2009 | Heating & Cooling
No heat through vents
Does your condo have more than one thermostat? if so there are powered dampers that open and close to direct heat where it's being called for. You may have dampers stuck/inoperative.
Mar 22, 2009 | Omega Trane Furnace Draft Inducer Blower ...
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
