Question about Dryers
I had to change the heating element on my whirlpool electric dryer. Now sometimes it makes a roaring noise. It started this right before the heating element went out. I think my main problem was that the vent to the outside needed cleaning out.
  • 31 Answers
Or that the bearing wheels are going out fr the drum try changing the vent hose to a rigid hose if it sounds like howling wind
Posted on Nov 17, 2009
My Whirlpool Cabrio just started making a clicking noise. It's only a year old. Any ideas?
is it a noise like nails on a chalk board if so your heating element could be hitting the back side of your dryer and making a clicking noise or scratching sound does it heat and dry the same
Jun 27, 2011 | Whirlpool WED9200SQ Electric Dryer
Dryer runs but no heat. Thermal fuse has been replaced, igniter appears to heat up. Will make noise when heating element lights up.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 17, 2011 | Whirlpool LGR3624JQ Gas Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
Whirlpool duet dryer not heating
Hi, Make sure you have 240V to the dryer. Remove the lower half on the front panel and you will find the heat element under the drum right side.
Start the dryer and test the element to see if there is 240V to it. If there is voltage, change the element.
If there is no voltage, UNPLUG the dryer and test the thermostats and the fuse for continuity. If any of these do not have continuity, change it.
I hope this help you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | Whirlpool GEW9250 Electric Dryer
Heating element heats up, but dryer will not spin.
Since you stated that the heating element is heating up I believe it rules out the thermal switches.
When you push the start button does it make the motor make any noise? Maybe hear the motor humming? Two things to check for are Broken Belt or Bad Motor:
This requires common sense and since you are going to be bypassing the safety features you need be CAREFUL.
First, with door open, manually press in door switch to by-pass door safety, then press "start", try to manually start the dryer by spinning the drum by hand, If you hear the motor humming but it does not start spinning on it's own; most likely it is a broken belt which can be changed without much difficulty for less than $15 bucks. NOW if it then continues to spin on it's own GET YOUR HAND OUT OF THERE and close the door; you have a bad motor and even though it started it needs to be replaced. A motor for that is available for just under $100 bucks and is not to bad to replace, I would recommend replacing the belt at the same time since you will be in there. Good Luck!
Apr 29, 2009 | Whirlpool LEQ7030KQ Electric Dryer
Roaring Sound During Operation of Dryer
Does the roaring sound occur after the machine warms up? If so, it could be a bad drum bearing. the heat from the dryer causes it to expand in its housing and, since it may been defective, could start "roaring". If so, The dryer drum shaft/bearing assembly will need to be replaced
If however, the roaring is immediate upon start up then u may have a bearing in your dryer motor. The entire motor may have to be replaced.
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
