Question about Vanguard International Blue Flame - Medium Open Flame Patio Heater
Fires, but pilot won't stay lit - Vanguard International Blue Flame - Medium Open Flame Patio Heater
  • greekgeekste Nov 17, 2009
    Thank you! One is working, but other is now only 'sparking'. The pilot came on initially, but wouldn't remain lit, per my original complaint. I'll blow it out and try again unless you have another suggestion. BTW, this one has always been contrary. lol
    Unfortunately or fortunately, I'm familiar with a thermocouple, thanks to water heater and range.
  • 31 Answers
Ther is a thermocouple in the flame that tells the regulator that there is a flame if the thermocouple is bad the gas automaticaly shuts off be cause of the safety feature or if it is not in the flame it cannot sense the heat
Posted on Nov 17, 2009
My jotul 200 direct vent gas stove pilot light won't stay lit. The pilot lights normally, and fires when the thermostat calls for heat. But when it turns off the pilot goes out as well. We cleaned ou
There's a little screw that adjusts the pilot light. It is usually on the block with all the other valves. Follow the pilot lite supply line to where the screw probably is located.
Nov 22, 2013 | Stoves Heating & Cooling
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Pilot won't stay lit...gaffers&sattler model B35
Hit the flame sensor next to the pilot with sandpaper. If it still doesn't work replace it.
Feb 26, 2013 | Heating & Cooling
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Model Ga3400T Pilot won't stay lit
This is caused in most cases by a defective gas valve thermal probe.
Dec 01, 2011 | Heating & Cooling
Pilot won't stay lit on furnace
Is that pilot automatic? If so then a quick easy fix for this is to located the sensor and replace it or clean it up with sand paper. After ignition the control is looking for verification of ignition from that sensor. How to videos
Sep 30, 2011 | Heating & Cooling
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Pilot is lit but the furnace won't fire up ,it fired up stayed on for about 2hrs. then the pilot just stayed lit
Hmm...well need more info...is the furnace switch on???? The breaker may have tripped...try the fan on Manual at the thermostat and verify the power is on....it really can be many things...need more info
Oct 18, 2009 | Heating & Cooling
Vanguard International Blue Flame - Medium Open Flame Patio Heater Logo
155 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
