Question about Cell Phones
How do I get the callers name to display on Motorola W376G
How do I get the callers name to display on an incoming call if I have that number stored in my phone book on Tracfone Motorola W376G.
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
Whenever i get an incoming call name of that
if the same no. is stored with two different names then it will not display the callers name.
Jan 11, 2010 | Motorola Mobility RAZR V3
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Incoming phone number displays but not the name in
Some nokia set has this kind of problem as we dont store the names with '+91' . This problem can be solved if the no is saved with '+91'.
thanks,
saumya.
Aug 04, 2009 | Nokia E63 Cell Phone
Don't get the name of a caller display on incoming calls. the number of the caller is stored in the contacts but just comes up with "Call" on any number. Missed calls also do not display a number just (no...
The caller is using private number. If you wanna know who's calling you, turn off your phone. If the caller always call you all the time, you'll be lucky. Because there will voice message received from the operator and you are able to know the number who's calling you.
You can do that also by typing "#31#(destination no.)" then call.
Jul 07, 2009 | Nokia 6301 Cellular Phone
Nokia E66 Incoming name or number of callers not
It's because the caller using voip (ie Skype or similar with hidden id)
Jun 04, 2009 | Nokia E66 Smartphone
Caller id
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Oct 13, 2008 | Panasonic KX-TG5672 Twin Cordless Phone
Caller ID
if you are putting 1 then the area code , just put in the area then the number and nt the 1 digit this should help
Feb 05, 2008 | Motorola Mobility RAZR V3
Incoming calls
both parties need to have caller id active
so if they are in your conntacts but don't have caller id opperating then the number won't be displayed
Dec 11, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
203 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
