NOT SPINNING!!IS IT THE MOTOR MAKE HUMMING NOISE THEN CLICKS OFF.. MOTOR??
  • 31 Answers
Yes bad motor or solinoids chek the motor connections and try to turn it
Posted on Nov 17, 2009
Motor hums but won't start
chances are the pump is blocked as well and unable to spin
Nov 03, 2013 | Dishwashers
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
My samsung front loader will not start. It hums and clicks and will not start!!
The humming noise is the indication of faulty motor or motor getting blocked.If motor checks ok check for the blockage in the drain pump.But first check for the motor.Is it getting a spin.If not then it has to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 30, 2010 | Samsung Washing Machines
I have a whirlpool washer and it will not spin
The problem will be in the main board or the spinning coil may be short circuited, You can easily check the motor during the spinning process you will find the humming noise if you do not found any humming noise kindly replace the board
Dec 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not agitate or spin, belt is fine. Motor is not turning, just making a humming noise. Is the motor bad or are there brushes that can be replaced or.....?
move the belt to see if it is not jammed and spins the rotor. If that is the case, the Humming noise is then an indication of a burned motor and not from a good motor trying to drive a jammed belt.
Oct 09, 2009 | GE WJSE3110A Top Load Washer
No spin cycle
dear zoofan.lets see hum.....to agaitate the motor goes one direction.to spin useing the same belt it goes the oposing direction.so when spins lid switch completes curcit to motor then it would spin so if click you hear is the motor protector switch [its like a curcit breaker] kicksout that means you lid switch is working. but could the noise be the timer advancing? timer makes clicking noieses also.then that would put into question your lid switch.but you said it starts again after a few minutes.if thats a sure thing then it ,your motor is involved but a possiable is somthing is between the tubs[thats a visiual inspection]sock,any clothing or if had a nail or somthing of that sort going thru small holes in inner tub then jaming or draging on the outer tub that could stop the tub but most of the time the motor would go and would burn the belt.hope i gave you a few clues,God bless ,tom
Jan 06, 2009 | Frigidaire FWS445RF
Humming noise during spin cycle
Strangely enough, the electronics in the motor drive circuits are quite hardy. Suggest if motor does agitate but not spin, check the motor brushes and see what length and condition they are in.Have had to replace brushes on many occasion.If you have a motor that has a capacitor then check the cap. It could be defective.
Feb 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
jasbo
jasbo
