I 97 interceptor engine in a 92 crown vic. I used the same trans that came with the 92 and I think it is AODE. I rewired the whole car with wiring from a 97 grand marquis from front to back. the car is still torn apart with just the dash and steering wheel in it. I try to start it and the starter just clicks. I know the starter is good but I can't figure out why it want start. the computer came form the interceptor so I believe i changed everything that I was suppose to, what else could be the problem. Note: the engine ran fine before I switched it over. This project has drained my pockets for the last six months and I don't know what else to do.
  • 31 Answers
Change the starter solinoid and check the wires from the starter for a short and if the engine is properly grounded sounds like the starter is not getting enough juice
Posted on Nov 17, 2009
Testimonial: "Thanks man you the greatest"
I got a 2000 crown vic. police interceptor an it came with no alternator, got new one and it came with 3 wires and my wiring in the car has 2 wires,whats with the 3'd wire.
They had a couple different alternators for that car,basically the same alternator but different regulators,might be where your trouble lies
Mar 23, 2013 | Ford Crown Victoria Cars & Trucks
Fuel pump wire colors 97 crown vic
Power from the inertia switch should be pink black and ground is black.
Feb 24, 2013 | Cars & Trucks
I have two questions 2001 ford Crown Vic LS, Codes read: (p0720 output speed sensor circuit), & (p1131 lack of heated oxygen sensor bank 1 sensor 1 switch indicates lean)........Keep in mined that I...
The PCM is programed for the LS engine parameters and now that you have changed engines the signal from the new engine are out of parameters> Either see if you can get the PCM reprogrammed at a dealership or purchase a new PCM and program the chip with the police engine interceptor to the vehicle> you may also return to the place where you got the engine and purchase the PCM for the police vehicle.
Mar 22, 2012 | 2001 Ford Crown Victoria
Im towing my crown vic 3000 miles do i need to remove the drive shaft
Definitely have to remove the driveshaft on a rwd crown vic, or you have to leave the engine running and the car in neutral to keep the transmission lubricated
Nov 27, 2011 | Ford Crown Victoria Cars & Trucks
Need to rewire 92 ford crown vic
Go to a salvage yard and pick up the whole harness, or take pictures and use that to fix individual melted wires.
May 07, 2010 | 1992 Ford Crown Victoria
1999 ford crown vic with ignition coils going bad a lot.
have look at ur wires that is caming from the car in to the coil it self
Mar 10, 2010 | 1999 Ford Crown Victoria
I put a "97 4.6 intercepter engine in my "92 crown vic. I toke the computer, the harness that runs from the computer, harness for the engine and the trans from the "97 Crown Vic before I junked it....
I did this once, not on a Ford and this is what I had to do to get it right. Get down to your local friendly dealer or an auto electric shop, put on a sad face and tell them your story and they will probably provide you with the wiring diagrams for the 2 cars. You need both. If that won't work go to faxonautoliterature . They have a wiring diagram book for the 92 for $19 and a Ford service manual for the 97 for $69. That will give you both wiring diagrams. It is an excellent company to do business with by the way.
With the diagrams in hand start tracing wires one at a time. You will find that a lot of the wires for the same things will be different colors, on orange wire in 92 will be green in 97. I don't know why they do that but they do. This should be able to get your car functional but you may be short a few options. I never did get my cruise control sorted out. Hope this helps and best of luck.
Nov 03, 2009 | 1992 Ford Crown Victoria
2005 Crown Vic Police Interceptor: Starts then stalls
Have you checked the fuel filter. Fuel pump will pressure up, but fuel filter could be clogged and not work without the pressure of the fuel pump.
Nov 27, 2008 | 2005 Ford Crown Victoria
Washing Machines Logo
Top Washing Machines Experts
