Question about Acer AX1200-U1520A PC Desktop
I plugged my hp desktop in to a 220 with out switching the voltage can i fix it
    Novelist:
  • 210 Answers
You can order a new or used powersupply and swap it out. From my experience when people do this it only blows the powersupply and nothing really critical.
If you like living on the edge and you're handy with a screwdriver, you might be able to check the glass fuse inside the powersupply, but I wouldn't recommend it to any first-timer.
Posted on Nov 18, 2009
How to fix couple of DELL desktops where I plugged them into 220 volts Power supply when they were set for 110 volts? More details below.
you could try replacing the power supply. if it still does not work, you probably fried the processor or motherboard. (or both). just make sure the replacement power supply has the same type of connectors on the power leads to the motherboard, hard drive, etc.
Aug 15, 2015 | Dell OptiPlex Computers & Internet
Hp pavilion a705w - blue power light flashing, won't turn on
On the back of the power supply there is a 120/220 V AC selector switch.
It's possible that switch got knock on the wrong voltage position.
Pull the power cable. Move the switch back and forth between the two position.
Make sure you leave the switch in the correct selection. 120v = USA
If you have time,open the case and inspect the RAM module(s) and card(s). They can be un-sitted.
plug in power cord and power on the pc.
Jul 29, 2011 | HP Pavilion a705w PC Desktop
How I can convert 110volts to 220 voltage in Craftsman charger 145301 because in the Peru country we use 220 v. thanks.
_Some_ chargers will allow a range of input voltages. This will probably be "Input: 100-240V" or something like that written on the charger. __You need to be sure__. Others may have a switch from one voltage to the other. The trick here is to make sure the switch is in the right position. In both cases you may also need a plug pin adapter. If the charger you have has neither of those abilities then you either need to get a different charger from Craftsman, or get a voltage converter, which will give both the right plug for your wall sockets and convert from 220V (from your wall) to 110V (to the charger). Unless the charger has voltage range or a switch, you can't just use a simple plug pin adapter.
Feb 20, 2011 | Craftsman Drills
I bought this computer in japan and has following power specification: 100-110v 6A and 200-240v 3A . wondering if it can be used without any problem in singapore?
If you don't know whether your devices can handle European electrical systems check the capacity of your devices and appliances before traveling. A gadget that has a dual voltage system usually indicates a 110-220 voltage, which means that you can use it in both American and European plugs and sockets.
Since your computer has "DUAL VOLTAGE" system it can be used any where in the world.
Dec 28, 2010 | HP Pavilion p6210f Desktop 26GHz 6GB...
Hi i have a desktop of compaq 1520il model having bestec smps.During switch on it was gave a loud sound & it was not working. when i extrct it from cpu unit & connect it with 220v ac back light was...
You connected a desktop computer to 220VAC?
I assume then, this is not within the U.S.A.?
It sounds like your power supply may have failed, which blew your home fuse.
Feb 05, 2018 | HP Bestec ATX-1956D 200w HP Part No...
I plugged my Acer desktop computer into 220 without switching the voltage - bang - circuit breaker tripped - can i reset the power supply?
yes you can try resetting it, make sure its on the right voltage setting, i hope the fuse is not broken, after resetting and it doesnt power on, please have it checked by acer service center
Oct 19, 2009 | Acer AX1200-U1520A PC Desktop
Converting from 220 to 110 volts
Most brands of air comperssors are built to work on either 220 or 110 v. I believe that 220 v compressors are more efficient and draw less current and run cooler.
The more expensive compressors have a switch allowing for voltage selection. Still others will have a wiring diagram printed on the motor allowing voltage change by changing jumpers. Most all of the sears compressors that I have repaired were of single voltage with no other way to change except change motor. Do not worry however, you have the better motor. It is easier to convert the outlet plug to 220 by isolating the circuit and installing a 220 v breaker. enjoy
Nov 15, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
An HP home PC boght in Peru 220 volts here its 110
All you need to do is replace the power supply, where the plug plugs into the back of the computer. Power supplies start at around $25.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 13, 2008 | Computers & Internet
Gateway computer 220volts
Hello.
If that is a desktop PC, you should look for a switch right next to the ac cord connector must the times it is red, you can use a screwdriver to set it to 115 V.( it moves laterally)
Otherwise you can change the power supply, if that is the case, tell me and i would help you to know what to look for.
if it is a laptop simply buy another adapter( 120V to whatever the input voltage of the laptop is).
i hope this help you.
Jul 11, 2008 | Computers & Internet
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Acer AX1200-U1520A PC Desktop Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
