Question about Maytag Neptune MAH5500B Front Load Washer
It will not spin belt is ok - Maytag Neptune MAH5500B Front Load Washer
  • 11,800 Answers
Have you checked that power is coming to the engine ?
If it is then it's the engine - it will be cheaper to replace the entire machine if you can't replace the engine yourself.
If it isn't then it's from the programmer - for this you will have to take it to a professional.
Posted on Nov 17, 2009
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Brush not spinning on my montiss turbo 850 vacuum. Hoover suction ok. Have took apart and deluded and still not working
Check the belt. If the beater bar will spin with the belt loose but not spin under power, the belt may be slipping.
Jan 28, 2015 | Hoover Vacuums
My Servis M3001 washing machine will not fast spin , it will spin and the belt seems to be ok , the machine is filling and draining ok , can you help at allThank you
Some times on front loaders if it is out of balance it will not go into fast spin. Try to remove some of the cloths and see if this helps.
Best of luck
'RR
May 15, 2014 | Washing Machines
Spin cycle not working properly
What is the model number of the unit?
Nov 07, 2012 | Washing Machines
The brushes do not spin, but the belts are ok
Check and make sure the brush spins freely by hand. If it does enen though the belt looks ok it will have stretched or has a glased spot. Try a new one.
Dec 01, 2009 | Hoover U6660-900 WindTunnel Bagless...
Won't spin fast, will spin slow
First I would check the belt. Make sure it has good tension and looks ok. No visible damage or anything. If the belt is ok then have the clutch replaced. This is usually the culprit. Once the clutch wears down to a point it can't maintain enough pressure to spin at full speed and begins to slip. This is why it only spins slowly. The whole thing shouldn't cost more than about $150 or so. Hope this helps. Good luck.
Jul 22, 2009 | Frigidaire Washing Machines
Spin cycles not spinning, does drain water before spin
check the wig-wag.it is the part near the cam bar.has 2 coils on it. also check the yellow wire going to the solenoid it may look ok but could be broke internally.
Nov 04, 2008 | Washing Machines
My washer intermittenly doesnt spin - not all water is pumped out
there is no belt, if the coupling was bad then it would not spin at all. Sounds like it could be a worn basket drive.
Oct 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Neptune MAH5500B Front Load Washer Logo
112 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
