Question about Panasonic Lumix DMC-TZ1 Digital Camera
The zoom switch of my Lumix dmc-tz1 is defect. The lens comes out when I switch on the camera. And then no function works. Where can I get such a zoom switch? Thanks. My e-mail adress is hvschalen@wxs.nl
I found an adress where I can buy that switch.
Thank you for your help.
Best regards, Harrie van Schalen
Posted on Nov 18, 2009
Lumix dmc-fs12c
Lens errors (System or Zoom Errors on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 12, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
Camera screen saying 'Please turn camera off then on again.' What does this mean Have done this, Battery ok. Deleted photos. Lumix DMC-TZ1
It is possible that the error is due to failure of the camera's main control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
The fault seems likely that the camera can have a stuck up mechanism or a jammed shutter. Hence unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Jul 29, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
The optical zoom has stopped working on my Panasonic DMC-FZ8. It was working fine, but now moving the zoom control clock/anticlockwise does not move the lens at all. I've tried the...
The issue lies with the lens assembly electronics and/or motor. If possible try another lens. If that one works it is the lens. If it doesn't, it might be the switch control for the zoom action.
Sep 19, 2017 | Panasonic Lumix DMC-FZ8 Digital Camera
Lumix DMC-TZ1 Memory Card Error
Try formatting the new card in the camera. Also, download any pics from the old card using a card reader and then, format it in the camera.
Apr 16, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
I have the Panasonic dmc-tz1 it keeps saying to turn camera off then back on. I do this and still cannot take pictures or use camera!!! HELP!
You surelly drop down the camera or you have some sand inside the zoom lenses movement. You need to open the camera, opens the zoom lenns the clean the gear or replace the broken gear inside lenses
Nov 08, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
I cant pictures DMC-TZ1
EVERYTHING WORKS FINE BUT WHEN i GO TO TAKE THE PICTURE IT DOES NOT TAKE.
Apr 18, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Will not zoom
its broken mine dose the same
May 19, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic DMC-TZ1
I just had this problem, too. I basically disassembled the camera by removing the back cover, front cover, and top assembly. The top assembly includes a plastic part between a circuit board and the top external metal piece that houses the button on the top of the camera. On the circuit board there is a switch for the zoom that looks like a pinball flipper. You have to make sure that it's working properly and you may have to remove the metal dust cap and remove any sand if it's lodged in the mechanism. It's pretty tough if you're not good with your hands because it's extremely small. I did this and the zoom began working like normal again, but then I got the message that the camera needs to be turned on and off every time I turn on the camera...
Sep 26, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
137 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
