Question about Mitac GETAC A 320 Notebook
What is the slot on the side for bought a wireless card but wont fit
How to install
Shut down the PC. Open the case: On the back there is a button that releases a panel at the rear of the top. When that is raised, the side comes off. Once inside, there are some connector slots on the motherboard. If you have dual video cards, you may not have any free slots! Remove the cover on the case for the slot you will use. Plug in the card. If there was a screw holding the cover for the slot, use it to lock in the card.
If you don't have any open slots, you can use a USB wireless adapter, and return the card.
Nov 05, 2013 | TP-LINK TL-WN350G, 54Mbps Wireless PCI...
I have a Samsung Intensity cell phone. I bought a
The Intensity has a slot for a MicroSD card -- is that the kind of removable memory you bought? (Anything bigger won't fit.)
Turn your phone off, and then pry off the back cover by using the little slot at the top of the phone (near the camera). There's a little groove where you can slip your finger in and pop the back cover off.
When the cover is off and you're looking at the phone's battery, the MicroSD slot is to the left, just above the camera button on the side of the phone. Stick the memory card in the slot (it should only fit in one way) and then reattach the back cover and turn the phone on.
Jun 08, 2010 | Samsung SCH-U450 Cell Phone
I`ve just bought a graphics card and i am struggling to install it in the mother board
hi this sounds like you may have bought the wrong type of graphics card for your motherboard, depending on the age of your motherboard they have changed over from AGP to PCI-e or even ePCI-e now if you have a slot that looks just like a PCI expansion slot at the top on its own away from the other ones, this will indicate a PCI-e or ePCI-e slot, if you have a brown slot at the top of the other ones this will be a AGP slot, just in case you have the right card, for the right slot, there is a locking clip at the end of the AGP slot that you have to pull to one side to put it in check to see if this is the case, then just do that.........hope this helps
May 22, 2010 | Evga GeForce 6200 Video Card - DDR2, AGP...
I purchased an HP A4327C desktop computer and wanted to convert it to wireless. I purchased a Level One11g Wireless PCI card and the card will not fit into the slot inside of the computer. Is it the wrong...
HI,
On your computers motherboard, you have three slots
  • PCI slot
  • 1 PCI express slot 16
  • 2 PCI express slot 1
You would require a PCI express 1 ex wireless card for the system
Thanks
Proton
May 11, 2010 | HP (EA118AA) 802.11a/g/b Wireless Adapter
Have brought a wireless card to go inside the laptop. Just not sure where it goes inside! There is a power supply cable and a long slot, but this is a tiny card and is far smaller than the slot, can it...
Must admit I am not familiar with this brand and a bit of googling suggests that this model already has built in wireless. However, some forum postings suggested that it in fact doesn't and that the required mini wireless card (which may be what you have bought) connects to the mainboard via a removable cover on the underside of the laptop.
Never come across that before - I have always had PCMCIA wireless cards which are about the size of a fat credit card, and fit in the slot I think you are describing. Sorry, not much to go on. I suggest that you ask Medion Support:
http://www.medion.co.uk/service/?ukshop
Sep 09, 2009 | Computers & Internet
Installing NIC card to dell optiplex gx100
NICs usually come in PCI interfaces. motherboards have usually four PCI slots to hold many devices such as NIC. just slide the card and fit it into the PCI slot. It could take any of the slots where it fits. the OS will detect it and loads the necessary drivers.
Aug 28, 2009 | Dell Ethernet Card Network Adapter
The camera says xd and sd compatible but it seems that the card is getting stuck and wont fit into the slot for the card?? any ideas why? i just bought the camera 2 days ago
The camera has one xD slot, and is supplied with an adapter which fits into the slot if you wish to use micro-SD cards. Regular SD and mini-SD cards will not fit.
Jun 29, 2009 | Olympus FE-25 Digital Camera
Make my Compaq Presario Laptop Wi-Fi.
If the wireless card is about the size of a thick credit card then it is a PCMCIA card device. This card plugs into the PCMCIA slot on either the LH side or the RH side of the laptop. You need to install the wireless card driver on the laptop and configure it to communicate with your wireless router which is connected to your Internet Service Provider. This wireless card can also connect to the Internet on free WiFi sites. As you are a novice, you will need a computer savy friend to help you or your friendly computer shop.
Jun 10, 2009 | Compaq Computers & Internet
Ack graphics card wont fit in any input slots
the adapter u are using is pci express and the dell dimension 9100 are not compatible.. try returning it for either a pci (usually the white slot) or AGP which in most cases is brown.. the AGP will be your best performance.. if return is not an option.. then it seems that a new pc is in your best interest.
Jan 07, 2009 | HIS RADEON X1950 PRO, (256 MB) Graphic...
Wireless Card will not fit in slot
First, make sure that the type of card that you bought is compatible with the slot. Your presario can use Type I or II standard PC or PCMCIA cards. If the linksys adapter that you bought is not a PC/PCMCIA card, rather an ExpressCard, it really won't fit.
Jan 01, 2009 | HP Compaq Presario 2200 Notebook
Mitac GETAC A 320 Notebook Logo
Top Mitac Computers & Internet Experts
matt
matt
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
