Question about Denon AVR-2807 Receiver
I need to set multi coponets
HELLO, I AM SETTING A HOME SURROUND SOUND UP AND I AM NNOT GETTING IT RIGHT. I AM SETTING DIRECTV , DENON 2807 RECEIVER,DVD, AND HDMI TV
    Problem Solver:
  • 8 Answers
Your best set up is to plug the DVD and the direct tv optical or coaxial out. The Denon has both. You will then have to choose digital input on the receiver. There is a blue indicator light that will light and a graphic that will show all speakers are working. There is also a pink noise test that will play each speaker in order. This test button is located on the remote.
Posted on Jan 11, 2008
No sound from Russound ss-4 after connecting to BACK surround speaker connections on the 2807.
Check the speaker setup configuration in the setup menu. Many times the surround back speaker terminals can be assigned to something else like zone 2. They may just be turned off.
Dec 27, 2012 | Denon AVR-2807 Receiver
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
Very hard to set up
Yes this should be ok.
Apr 03, 2010 | Denon AVR-2807 Receiver
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
Can't get the sound to work on my TV using the Denon AVR-2807
In the 2807 the HDMI out is a video out only. Audio is not processed through the HDMI output.
If you are using speakers it is best to adjust the playback modes to stereo if you are annoyed with surround sound modes.
Please comment if I helped.
Oct 04, 2009 | Denon AVR-2807 Receiver
Want to put set of outside polk speakers to Denon avr 2807
Do you have outputs for both A and B speakers? If so you can easily hook the outside speakers to the B outputs.
Jun 16, 2009 | Denon AVR-2807 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
How do you reboot the Denon AVR-2807 to factory settings
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory. Enjoy this info is straight from Denon's Tech support. I had to do this on mine
Nov 25, 2007 | Denon AVR-2807 Receiver
Denon AVR-2807 Receiver Logo
121 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
