Question about Kenmore 44102 Front Load Washer
My kenmore front loading washer machine is very loud and banging. I ran it with nothing in it-same result-i can turn it manually and it moves from side to side-is this something i can fix?
  • hutchjth Nov 17, 2009
    sounds great
    how do i remove the sides?
    thanks
    how do i take the side off a kenmore washer machine to fix the tub
    Top Expert:
  • Kenmore Master
  • 76,691 Answers
You are going to need to replace the washer rear drum/tub bearings and the shells, this is a very involved job and on a scale of 1-10 with 10 being the most difficult it is an 8.
if u are curious about the parts failure watch the video at link bleow.
http://www.appliancejournal.com/appliance-repair-help/washer-repair/why-kenmore-front-load-washers-fail-271/
Posted on Nov 17, 2009
  • yadayada
    yadayada Nov 17, 2009
    here are the instructions to replace the parts.
    Rear Tub Bearing Replacment
    (Part 2 of 3)
    DISASSEMBLY:
    1. Unplug washer and turn off water supply.
    2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
    3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
    4. Remove the lower panel under the door (if you haven’t done so in the previous step) and remove the washer top and back panels.
    5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
    6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
    7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o’clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
    8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
    9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
    10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
    11. Remove the back casing brackets so the entire back of the washer is open.
    12. Remove the rear counter weight from the wash tub to minimize some of the weight.
    13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
    14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
    15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
    16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
    (cont’d)
  • yadayada
    Rear Tub Bearing Replacement
    (Part 3 of 3)
    REASSEMBLY:
    1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
    2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
    3. Lay the washer casing down over top the washer tub shell.
    4. Insert the upper shell support springs into the wash tub and support spring brackets.
    5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
    6. Re-install the washer support shocks.
    7. Re-install the drain line hose.
    8. Re-install the Motor Control Unit and Drive Motor.
    9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
    10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
    11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
    12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
    - Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o’clock position.
    - With both hands gradually work your way around to the 4 and 8 o’clock positions and stretch the spring apart.
    - Push the spring and hoop into the groove.
    NOTE: It may require a second person to get the door bellow back in place.
    1. Re-install the rubber dispenser hose to the top of the wash tub.
    2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
    3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
    Some other parts that may have to be considered when performing a rear tub shell replacement:
    - Rubber Door Bellow
    - Spinner Basket (if arm supports are damaged)
    - Front Tub Shell (if signs of internal damage)
    - Drive Pulley (can sometimes become damaged trying to remove old one)
    - Drive Belt (check belt during parts removal for wear)
    - Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
    NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required
  • 11,800 Answers
The counterweights are loose or the fixings of the tub are worn out - remove the sides and just see where's the problem, easily fixable. Replacement parts are available at repair shops.
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Feb 22, 2010 | Kenmore HE2 Plus Front Load Washer
Making loud banging noises. Sounds like something is inside, but nothing is. Something seems to be between the basin(?) and its casing.
It is very common for an item to get stuck between the basin and casing. You can drain the washer and spin the basin manually a few times in either direction. It should spin smoothly, but with some resistance. You may need to remove the front cover by typically lifting the top enough the loosen the front panel, then inspect the perimeter of the basin and the condition of the belt and motor. Remove anything that doesn't belong (i.e. a sock or zipper!)
Hope this helps! Rate my solution!
Jan 05, 2010 | Kenmore 44102 Front Load Washer
My kenmore 417.42042100 model front loading washer is making a loud banging noise during the spin cycle.
Here's what the problem is.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=player_embedded
It's been designed to fail so that you buy an expensive part.
Nov 26, 2008 | Kenmore 46462 Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Banging during high speed spin cycle
Laco, drop the bottom front panel and see if all of the shocks are in tact on the tub assy. They just insert and lock by turning. If these are ok, check the back belt pulley. Sometimes one of the tines will split or crack and you will get this symptom. Catriver..post back.
Mar 04, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 44102 Front Load Washer Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
