Question about Samsung DVD-V3500 DVD Player/VCR
How do I reset the time? Right now is it just
How do I reset the time? Right now is it just showing dashes.
    President:
  • 1,335 Answers
You can download the manual for the DBD-V3500 at
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
beginning on page 18.
Posted on Nov 17, 2009
How do I reset my tire pressure light when tires are fine
My Lesabre has buttons on the left side of the dash. The one called Gage Info has a number of things like oil pressure check tire pressure heat Battery. Push this button till it says check tire pressure To reset your light push the reset button and hold for fifteen or twenty second and the light on the dash should go out and it will show tire pressure ok on the gage. Before you reset check all four tires for air as one tire could be down 8 or 10 lbs and the light will come back on. they all have to be the same pressure.
When you change your oil you should reset the oil section as well and hold reset the same as above. The oil section tells you how much oil you use over an amount of time.
Apr 01, 2016 | 2004 Buick LeSabre
Replace egr valve and check engine light keeps comming on
Might try resetting the system by disconnecting the battery lead for a few minutes. The system may be confused with the disconnection and new install, so removing power may reset it. Also, there is a engine light reset switch under the dash. Not exactly sure right where it is, but it is just a simple switch that can be moved from one side to the other. Like a toggle switch, but smaller. This resets the engine light headache and starts a new counter for the next time it lights up for something. Mitsubishi placed these switches on all there vehicles. My 86 truck has it right behind the speedometer under the dash. I use to have to switch it every 50K miles because it was programmed to turn on in that time range. I finally got tired of it and removed the bulb from the engine light warning thing. I don't suggest you remove the bulb,, but I do suggest you look under the dash for that reset switch and flick it to the other side for normal reset procedure.
Jul 02, 2014 | 2003 Mitsubishi Montero Sport
Shows dashes for some cycles and doesn't start
Try resetting it by shutting power of and back on. Or just unplug it and plug it back
Apr 10, 2014 | Dryers
Check Engine Light 2003 X' Type 2.5 Told that previous owner drove the car for a long time without resetting and it will take 3 to 15 resets before it sets permanently. No codes show up on the reader...
When you reset a DTC (Diagnostic Trouble Code) on any OBD2 vehicle (Late 97 and up) you have to drive it for an unspecified period of time after the code is cleared before it will pass an emissions test. This is so people don\'t clear them right before going for an inspection.
If the light was on, there is a problem. Rarely does resetting the code fix it. I would run it until the light comes on then read the code. You can assess the problem from there.
Jun 18, 2013 | Cars & Trucks
How do i turn off the brake warning light on range rover 2004
You can reset this fault code using the buttons on your dash - you don't need a dealer to do this. As you already know, you need to replace your pads and the brake wear sensor - this is a sacrifical item. Once this is done, do the following:-
Using the buttons on your dash - there are 2 - one on the LHS (Trip reset) and one on the RHS (In between Tacho and temp gauge)
*Press and hold Right button and turn ignition to first position (I or Accessory)Display should show "Check Control OK" then a short time later "Test Nr.01"*Press the Left button and you should see the car info in the display. Add the last FIVE digits of the car identity number together (NOT all 6!) to get a unique ID for your car.*Press the Right button repeatedly until you see "Test Nr.19"*Press and hold the Left button until you see the number matching the unique ID you calculated, then release.*Press the Right button to select this.*Press the Left button repeatedly until you see "Test Nr.21" - Reset All Defect Codes*Press Right button to reset the codes.Done!
Mar 26, 2012 | 2004 Land Rover Range Rover
How to reset the trip odometer in a 2002 jaguar x type
To the right (UK)/left(US) and on the dash below the sterring wheel level (near Fog light switch) you will see three buttons A B and Reset. With dash display showing trip millage of the one you wish to reset (A or B) press and hold the reset button for 5 secs.
Vist http://www.bluejag.co.uk for other useful info on your X-type
Dec 26, 2011 | 2002 Jaguar X-Type
How to set the clock on a 2000 BMW 325i
Hi, on your signal stalk (left side), see the "BC" button?
Push this BC button repeatedly, and you will notice the display inside your dash go from:
Time-Temperature-MPG-Range-Ave speed-(and back to)Time.
Notice there're also 2 buttons (stalks) sticking out from your dash.
ONLY while the display is showing the TIME (not anything else), TURN and HOLD the right button inside the dash. You will find that the time will adjust on both your dash and your radio display. It will move faster as you keep holding on.
You may also switch from 24hr format to AM/PM format by pushing the right button instead of turning it.
Jun 02, 2011 | 2001 BMW 325
Nothing will display on the read out
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
The veh won't start. The dash shows a picture of
your passkey security system has been activated, try this reset procedure with the original key for the truck
PASSKEY LOCKOUT RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key.
Sep 07, 2009 | 2006 GMC Yukon Denali
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Samsung DVD-V3500 DVD Player/VCR Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
