Question about Cell Phones
Hello i am having text messages not going through and not recieving them maybe a day late and if i do recieve the text message it shows as a blank message known as no content on my cell phone can someone please help me verizon isnt much hlp to me just keep giving me a referbished phone that gets worst and worst
Tip
Cant send or recieve text messages on my mobile phone
hi, if you are having trouble sending or recieving text messages then the fisrt thing you need to do is delete all the sent and recieved messages and also drafts due to the fact that if your memory is full this will give you loads of problem sending and recieving text or mms messages so deleting these will then get your messages working again.
If how ever you still cant send or recieve text messages then the chances are that your message center number is wrong or got mest up, what you need to do is contact your service provider and ask them to send you the text message center number settings, they will then tell you the correct message center number and how to change this setting on your phone.
They wont charge for this and it will only take 2 minutes to solve your problem.
on Dec 03, 2009 | Cell Phones
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
I always receive my text messages a day or two late
is ur service good? if it is all that i could say is try calling ur carrier.
Jan 30, 2009 | Motorola Mobility ROKR E8 Cellular Phone
I can recieve text messages, but i am unable to send text message
go to settings ---> call barring ---> then click on Data calls ----> cancel .
this should enable sms send and recieve.
Jan 03, 2009 | Motorola Mobility RAZR V3
Lg me770 shine. how do i set up to have mms
i used this for mine. it works alright for recieving and sending. but im still having trouble recieving from black berries.
go to menu
settings
connectivity
network
network profile
bearer: GPRS
APN: wap.cingular
user ID: blank
password: blank
primary server: 0. 0. 0. 0
secondary server: 0. 0. 0. 0
then press ok.
now go to menu
messaging.
message settings
multimedia message
network profile
profile name: Cingular MMS
MMSC: http://mmsc.cingular.com
internet mode: http
proxy ip: 066.209.011.032
proxy port: 80
connection: media net
hopefully this works for you guys.
Dec 11, 2008 | LG Shine KE970 Cellular Phone
Blank messages
you could take the phone to a mobile service center and ahve them reflash the firmware for you.
Sep 26, 2008 | Motorola Mobility RAZR V3
Cant recieve text messages
Maybe you never activated the phone to receive txt messages. Call up sprint and activate incoming txt.
Apr 23, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Samsung m500 sends text but the recipient does not always recieve the text
Hi! The best thing you do is contact the company that your phone isconnected then tell them to activate your text message, maybe your phone line providers did not or they disconnect your text messaging hope this solution help you Thanks !!!!
Mar 23, 2008 | Samsung SPH-M500 Cellular Phone
I can send my text messages but i can't recieved any text messages in all networks
Check Your Message Centre Number With Your Network Provider.The Number Will Be In The Messages Menu In Message Settings And Then Text Message Settings.It May Be Different On Your Phone But Similar.
You May Have Accidently Changed Something.
I Would Also Check That Ypu Havnt Disabled Recieving Text Messages.
Maybe This Helps You,I Hope So.
Regards,
Sophie x
Feb 14, 2008 | Sony Ericsson K750i Cellular Phone
Cell Phones Logo
180 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
