Question about Bosch Classixx WFL 2066 Front Load Washer
The machine wheel inside wont go round
When knocking on the machine it will fill with water but the drum wont turn round, it does drain but wont spin
  • Bosch Master
  • 3,463 Answers
I suggest that you remove the motor, and check the brushes in the motor.
If there is less than 3 or 4mm left, then replace them.
Please rate my solution.
Thanks.
Posted on Nov 18, 2009
Testimonial: "thankyou, ive bought another one now but thankyou anyhow"
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Beko WMI71641 won't agitate or spin - drum doesn't move!
your pump is blocked,at bottom of machine there should be a flap with a round plug in middle .unscrew,it will have water come out so use a bowl or big towel.the impeller should turn freely,once plug is unscrewed at front put washer into a drain program see if the pump turns.if this is free youll need to get the pump off(unplug machine first)and then feel inside the big pipe from the drum to pump.it may have a sock or something like inside.this means it will work but wont get out all the water.also note when trying to spin a pillow,or big towel the load will be uneven so it will reduce its spin speed so it doesnt destroy its self
Apr 16, 2014 | Beko WMI71641 Built in washing machin
Machine is filling with water but the drum wont turn or spin
MOST LIKELY THE MOTOR IS SHOT OR THE BELT AROUND THE DRUM CAME OFF THE DRUM
Feb 06, 2013 | Washing Machines
The drum will not go round
Possible belt snapped or motor brushes need replacing.
Jan 24, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
My washer fills up, but not inside the machine. If I put the machine on spin, the water drains out. Why won't it fill inside the machine?
The water is going into the machine, but somewhere below the inside drum. I can hear it sloshing around if I move the inside drum. If I put it on the spin cycle, it does not spin, but the water comes out of the hose and into the sink.
Nov 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
The drum wont go round
either motor faulty or carbon brushes worn down take motor out and inspect
Jul 08, 2009 | Washing Machines
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
May 07, 2006 | Indesit W 123 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
152 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
