Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Wash impeller wont rotate on fisher paykel model 603
  • Fisher and P... Master
  • 3,247 Answers
I suppose you have a double drawer dishwasher and this problem is with one of the drawers.
One cause of the impeller not rotating would be that there is some loose cutlerry lodged between the impeller arm and the base rack. This is easy just remove it.
HOwever, the other option is that the impeller itself is stuck. Try opening the filter base plate and removing the impeller rotor to check if no debris is lying around (usually food scraps).
The instructions to open the filter plate and exposing the impeller is in the user guide. If cleaning does not help then check nothing is stuck in the filter sump and the narrow passage connecting filter sump and the rotor cavity which is preventing the rotor from rotating.
The worst case scenario is the impeller rotor is faulty. You can buy this and replace yourself , ie, if you worked out how to remove it.
Good luck
Posted on Nov 18, 2009
Screeching sound during cycle
Check for debris in the pump impeller. Your owner's manual will describe how to
1. Remove baskets
2, Remove wash arm
3. Rotate (inner) lock ring on stainless steel bottom plate to release and remove it.
4. Rotate top impeller by hand to feel for rough spots indicating debris in lower impeller.
5. Rotate motor assembly lock ring to release rotor assembly and clear debris from sump.
6. Reassemble in reverse order and check operation.
This can also occur with a drawer that is not run often (less than once or twice per month) and indicates a dry bearing surface. Most often running a rinse and hold once or twice frees this up and corrects the problem. Drawers work best when operated once a week or more.
Sep 04, 2016 | Fisher and Paykel Dishwashers
Wont start
Please be a bit more specific when you say "Won't Start".
If you are able to set the program but nothing happens when you press the start button, then it is very likley the proximity switch that detects drawer close, is failing and not letting the controller start the cycle.
Mar 23, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
After replacing a hot water hose on my Fisher & Paykel Smart Drive 603, the machine now needs to be rre-set I think. Where would I find that button please??
Hi just read your posting.Why do you think the machine needs to be reset?Is the machine working?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
May 20, 2011 | Fisher and Paykel Fisher & Paykel Washer
Washing machine wont spin
If your washing machine wont spin it and wont empty the water it is a blocked drain pump. You may have a faulty lid switch or it could be going out of balance.
Feb 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Our Fisher and Paykel 603 smart drive has stopped
most likely your problem is your lid switch visit your local spare parts dealer and purchase a new one
Feb 06, 2010 | Fisher Washing Machines
F2 Fisher Paykel 603 issue
You can download the service manual from
http://www.fisherpaykelparts.net/index.php?categoryid=115&productid=18 at a cost of $20
But if you can go through the user guide which is free from
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
you should be able to work out how to remove the impeller and rotor once you have taken out the filter plate. It needs a slight twist and pull at the same time. It is likely there is some debris between the drain filter and the rotor cavity. You may need to insert a thin stiff wire through the drain filter sump.
Oct 27, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel washing machine model- smart drive 603 how do we programe the favourite cycle button? thanks
prss and hold the fav button till u hear 2 beeps , set whatever u want it to be and then prss and hold the button till u hear 1 beep turn power off , set
Oct 27, 2009 | Fisher Washing Machines
My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Wont drain
Check the drain line for kinks and obstructions. The pump can be checked. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken or missing blades and that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump or jammed impeller. Very sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | Fisher and Paykel GWL11 Top Load Washer
NOISY WHEN DRAINING ON OCCASION
This is a sign of a faulty drain pump impeller. the drive shaft that is connected to the impeller is stripping the impeller. you will eventually need to replace the entire pump soon.
Jun 06, 2009 | Fisher Paykel Eco IWL16
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
279 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
