Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Making crack noise from bottom when tv is on - RCA D52W20 52" Rear Projection HDTV-Ready Television
  • RCA Master
  • 5,138 Answers
You really need to remove back then with TV on see if you can tell where the noise is coming from! Most of the time its hard to say what maybe wrong because these TVs can do so many different things, so remove back then once you think you might have where the problem is repost it again also RCA made so many different Deflection boards and SSB boards they all look alike But they do connect up differently
Posted on Nov 18, 2009
CRACKING NOISE COMING OUT THE SPEAKERS
Your speakers need replacing or you could turn down the volume till it stops and use it like that if it's not too quiet.
Sep 21, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
My TV is making cracking noise
Its the plastic cassing making the noise. If you press the tv together along the edges you will here a crack. Samsung and others did not use 99 cent padding between the plastic and the metal you need cushion padding. Its like not using a gasket or seal. Its a simple fix but the tv companies say its expansion.
Oct 30, 2008 | RCA 14F512T 14" TV
Cracking noise SAMSUNG LCD TV
I wouldn't recommend doing anything yourself because you can easily make the problem worse. I would recommend calling samsung because it's been under a year and see if they cover the problem. If you open the tv, that could void the warranty so I would try samsung before doing anything to it.
Oct 20, 2008 | LG RZ-37LZ30 37 in. LCD Television
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
Hitachi 65 in rear projection tv
can you identify the flashing item because it sounds like the flyback or the high voltage splitter can you send me a picture of the part thats flashing white please?
May 09, 2008 | Hitachi 65F59 65" HDTV
Toshiba TV 36''
  •  this cracking on my tv. It cracks and makes lots of noises
  • it sounds me that your speaker paper cone has become hard or paper has damaged. so best remedy is to change speaker.
  • if it is ok then replace all electrolytic  capacitors in audio output section.
  • check supply to ic or ic.
  • hope this will help.
Oct 11, 2007 | Toshiba CF36G40 36" TV
Cracking and poping with Yamaha surround sound system
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
