Question about Brother MFC-7220 All-In-One Laser Printer
I want to use old same (refilled by me) toner cartrige in my brother laser priter MFC- 7220.But priter electronicaly detecting old toner cartrige.So how I do full factory reset or erase old memory so priter will not detect old toner cartrige? I can reuse old refill cartrige.
  • smr_narkhede Nov 18, 2009
    my brother printer do not have any leds only display.I think this solution is for difrent brother model.
  • 4,472 Answers
Have you tried this:
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
If you still need assistance please let me know.
Thank you,
Lee
Posted on Nov 18, 2009
  • 17,970 Answers
How do I reset the printer to factory defaults? How do I perform a factory reset?
Follow the steps below to reset the printer to factory defaults.
1. Check that the front cover of the printer is closed. Turn OFF the
power switch on the right side of the printer.
2. Turn ON the printer power switch while holding down the GO button
until the Toner, Drum, and Error LEDs are lit.
The GO button is located on the top left side of the printer below the
Toner, Drum, and Error LEDs.
3. Release the GO button. All LEDs will be off.
4. Press the GO button 8 times. The Ready LED will flash while the
printer is reset. After the printer is reset the Ready LED will be lit.
Support MFC 7220
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset. Re-filling them will have no effect.
Sometimes, the continue use of compatible inks cause damage in theheads. I suggest use 1 x 1 in the next time. Review the head ink.
Also can review HERE
Hope helped.
Posted on Nov 17, 2009
-what do I do My MFC-7220 is printing faint-56% drum life and toner low indicator not on
It sounds like the corona wire may be dirty. Its a wire that self-charges to attract toner to the paper. Read your manual and see if it mentions print quality problems. If you decide to check inside this device, please disconnect the power cord.
Feb 28, 2015 | Brother MFC-7220 All-In-One Laser Printer
My brother mfc-7220 printer show"toner
You do not necessarily need to replace the toner right away. The toner has 2 visible clear tabs when you are looking at either side of the toner cartridge. This is for a reader built into the unit to recognize that the toner is low. However, if you cover those clear plastic pieces with black electrical tape, you will be able to achieve an additional couple hundred prints and when the toner no longer prints on the page, you are definitely out of toner.
Sep 21, 2011 | Brother MFC-7220 All-In-One Laser Printer
My Brother MFC-7220 shows the error message "Dust
Try cleaning the drum in the toner cartridge with a soft cloth. If this does not work then a replace toner cartridge is the other solution.
Nov 26, 2010 | Brother MFC-7220 All-In-One Laser Printer
Put in new toner still says toner needs replacement ? Using original Brother toner?
Brother says a standard toner cartridge will print about 3500 pages ... Things You'll Need: Replacement toner cartridge; Piece of paper ... Turn off the printer and allow it to cool for at least 15 minutes, if you have been using it recently. ... Put the new toner cartridge in the printer same way the old toner ...
www.ehow.com/how_6394835_change-toner-brother-mfc_8220.html
Jul 20, 2010 | Brother MFC-7220 All-In-One Laser Printer
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
Need new drum for brother mfc-7220 all in one. Not even 1 year old. Is there something I can repair or fix instead of replacing the drum for about $100+ ?
If the print quality is still good, just reset the drum counter. Open the front door, press OPTION, press 1, close front door.
Oct 05, 2009 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC6800-says change drum soon - is that hard to do?
yes anyone can do this, the drum is the unit the toner fits into, remove as though you were removing the toner cartridge, that the toner all the way out of the drum unit and install the old toner in the new drum and slide back into printer, again the drum unit is just the casing that your toner cartridge slips in and out of
Apr 02, 2009 | Brother MFC-7220 All-In-One Laser Printer
Replace ink toner message
Is it refill? if not then try leveling powder in cartridge by gently shaking, Take back as faulty, or reset new toner lever on left front of cartridge. Check toner is seated correctly in drum and drum seated correctly in machine.
Nov 08, 2007 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
117 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
