TV acts as if it is getting no power. I work 3rd shift and came home one morning and the power light on the TV was on, but the TV was not working. I turned the TV off and the light went out and we haven't been able to turn it on since then.
  • 610 Answers
Probably a blown power supply board.
Posted on Nov 17, 2009
2007 Chevy Avalanche 3rd and 4th gear are not working
From what you are describing, it is possible either the 3-4 actuator is no longer playing with the 3rd & 4th clutch packs, only way to know for certain is to hook up the good ol' pressure gauge to trans. system, yeah, you think the Chevrolet dealer should know this right?
Sell it now if you can!
Smiles
Mar 02, 2014 | 2007 Chevrolet Avalanche
Shifting problems 3rd to 4th
run the fault codes and look for a TCM problem
Mar 01, 2014 | 2000 Chevrolet Silverado
46re won't shift into 3rd gear
first of all have you had the car scanned before you try anything else get the vehicle scanned this will give you a direction to work on .if codes are not cleared the vehicle will stay in limp as it thinks its still broken start there give me codes see what i can help you with
Jan 27, 2014 | 1994 Nissan Pathfinder
Downshifted from 4th to 3rd and both gears went out?
get your codes first. as three things in your transmission can go wrong.the pressure sensor.the governor pressure sensor is failing.and your filter in the box very dirty and needing changed .so get the codes first cheaper.
Dec 13, 2013 | 1999 Jeep Wrangler
I have a 2006 mazda 3. Out of no where my brake lights stopped working and my AT wont shift out of park. Ive replaced the Brake light switch and that didnt solve the problem. All fuses under the hood and...
i had a similiar problem yesterday.. apperantly my thermostat was leaking on the alternator causing it to act up. my brake, ABS, Ppowe steering lights went on, got stuck in a 3rd gear. lost power steering and brakes.. had to pull the handbrake to avoid getting slammed into a light pole
Mar 30, 2010 | 2004 Mazda 3
It shifts from 1st to 2nd OK But will not shift from 2nd 3rd until way late and then acts as if it is slipping in 3rd. Seems work almost ok when it is cold 94 Ford E 150 conversion van
CHECK TRANSMISSION FLUID LEVEL.IF ALL IS GOOD YOUR 2 - 3 SHIFT VALVE IS STICKING OR BINDING.GOVERNOR VALVE STICKING.YOU COULD HAVE STICKING OR BINDING ACCUMULATOR VALVE 3 - 2 CONTROL VALVE TV LIMIT VALVE 1 - 2 OR 2 - 3 SHIFT VALVE TRAIN.CHECK THE VACUUM VALVE IF EQUIPPED.USE HAND HELD VACUUM PUMP.PUMP VALVE TO 15 HGS. IF IT HOLD VACUUM OKAY IF DONT HOLD VACUUM VACUUM VALVE NEED REPLACING.
Mar 04, 2010 | 1991 Ford Econoline
I have had my tiburon less than a year but about a month ago the transmission started to act weird. At first it began shifting between i think third and fourth gear which made the rpms go higher than they...
the trans computer has seen a problem possible a bad sensor, or an internal problem, and puts it into a safe mode, or limp home mode , it wont shift , it will stay in 3rd gear, this way this reduces the possibility of further damage trans damage, when you turn the ignition off and back on it resets the tcm, my advice is to take it to your local dealer, they can diag your trans as they know the product, i dont advise pep boys, or discount auto parts.
Nov 18, 2009 | 2001 Hyundai Tiburon
I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Aug 13, 2009 | Televison & Video
2004 mazda 3 transmission problem
Check transmission fluid. If that is full, try changing the fuel filter. It could be starving for gas, and trying to shift but can't. It could also be the speed sensor, or shift solenoid.
Jul 06, 2009 | 2005 Mazda 3
No power. No lights.
I have the exact same problem.
TV was working fine (if you call having to deal with blinking lights of death and multiple starrt up errors...) - but I powered through it all.
This TV is 6 years old and started acting up after the 4-year extended warranty ran out.
This morning I went to turn it on and nothing.
Hmmm... Got my manual to count the blinking light code...
Whoops. No lights. Nothing. Checked plug. Checked power.
Uninstalled and installed lamp. Checked plug and power again.
Nothing.
Not one stinking light. No power to fan. Nothing.
How does a TV just DIE???
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Electro Med Services...
