Question about Sony Playstation 3 (PS3) Console
Ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
How do i connect ps3 to bt home hub wireless router ps3 is upstairs and pc downstairs
  • Anonymous Jan 13, 2009
    i have a playstation 3 and have ordered the internet from BT. i dont have a computer or laptop.
    so my question is, can i connect my ps3 to my bt hub without the laptop or computer??
Look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Posted on Jan 21, 2008
My telephone connector is downstairs, and I want to have my PC upstairs - but I do not want to run wires around the house. Is there any way I can connect my computer wirelessly. i.e router downstairs,...
Yes, a wireless router should work fine.
You'll need a wireless-adapter (either internal PCI add-in card, or external USB stick) in your computer, if it does not have built-in wireless capability.
May 22, 2011 | Computers & Internet
I got a wireless network connection home but the modem and router are both upstairs while my ps3 is downstairs. i bought wireless-g range expander model no. wre54g in order to expand my wireless network...
Hello
This not a big deal for a wireless network to work on downstairs, you need to check your connection and settings of the routers/computers. or just put a repeater for improvement of signal strength.
If the matter is signal strength, for the purpose see the TIP link below
http://www.fixya.com/support/r7245572-improve_signal_strength_wireless_network
Good Luck
Dec 13, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Cant connect to internet with main computer, one upstairs is fine
The upstairs computer is wired or wireless ?
If the upstairs computer is working then the router must be working properly.
Check the connection between the downstairs computer and the router.
If it is a wireless computer then check the wireless connection status on that computer.
Click Here for step by step solution
Nov 05, 2009 | Belkin Computers & Internet
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
D-Link DIR-628 router, i've lost internet connection to the PC!
Did you use MAC ardress filtering to grant ps3 access to router?
if so you have to do the same with your cpu's wifi mac adress
Nov 21, 2008 | Computers & Internet
You would be best to buy a wireless router with a built in modem, this would be much easier for you to setup and manage
Nov 16, 2008 | D-Link AirPlus DI-524 Wireless Router
ENTERNET CONNECTIONS FOR PS-3 80GB
if you want to be able to play your ps3 downstairs with your modem upstairs, you might consider buying a Wireless Router that has Wireless G , for your PS3.
This will allow you to access your Internet all around your house without wires. I suggest looking for one that features MIMO or range plus max, or anything else that increases your signal range since there is a fair amount of distance involved.
The alternative is relocating your modem downstairs and hooking it up to the PS3. BUT your computer wont have Internet.
Aug 02, 2008 | Sony Playstation 3 (PS3) Console
Bt 1800hg
You'll need a way for your computer upstairs to connect to the hub/router. You can most likley get away buying a low priced wireless USB adapter like this one. http://www.newegg.com/Product/Product.aspx?Item=N82E16833340004
If your router has wireless security (such as WEP Encryption) you'll have to know the (WEP) key and SSID of the device in order to connect.
Feb 23, 2008 | Computers & Internet
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Sony Playstation 3 (PS3) Console Logo
552 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
