Question about HP Photosmart 3210 All-In-One InkJet Printer
I'm trying to copy from 8 1/2 x 11 paper to 8 1/2 x 11 paper. But the printer says the paper size detected is not supported. Job cancelled. It printed fine a couple of days ago and I've changed NOTHING! Can you help?
    President:
  • 2,306 Answers
That error comes from the sensor on the right side of the carriage at the bottom. There's a light that shines down on the paper to determine size. Unplug your machine with the carriage in the middle and use a damp Q-tip to wipe up under the right hand side of the carriage. The Q-tip should come back dark blue and that error should go away.
Posted on Nov 17, 2009
Copier prints fine from computer. When asked to copy from a document placed on the glass, error message pops up"paper size detected is not supported. Job cancelled." The paper is the same we have...
If the copier is working fine as a printer using you computer as command , then nothing is wrong with the copier . But if you want to place a document on the glass and make copies , then you need to push on the copier machine the " start " button . You will be back on business .
Cood luck . Wilson
Feb 16, 2011 | Office Equipment & Supplies
Photosmart 3110 xi copy problem - says ''paper size not supported. Copy cancelled.'' any size paper causes this response. What can I do to fix it?
Press the copy menu on the printer.
select copy paper size that you are using.
Then select copy paper type as plain paper.
Then press Ok.
Try copy.
Mar 14, 2010 | HP Office Equipment & Supplies
My MF 5700 has a red lamp blinking and notification-check paper size constantly, even when I restart it, wont print anything, paper size is ok...
If you are printed on it, check the paper size under printer properties, to "get rid" of blinking cancel job or print, copy and turn off and on
Jan 13, 2010 | Canon Office Equipment & Supplies
It doesn't print It says size paper error
This problem occur when ink head is dirty and also the head cleaning plastic mechanical cleaner is full of jammed color. 3210 model can be opened and the ink head plastic cleaner can be changed. The ink head is the moving part on the metal axel.
Isopropanol is good for cleaning.
Oct 06, 2009 | HP Photosmart 3310 Printer
My HP 3210 won't make copies
HP has a pretty good online troubleshooting site, accessible at support at www.hp.com. I'm not familiar with that particular error, but you might try the steps outlined in this link for starters...
If changing the size settings doesn't work, try changing both size and type and rebooting, then changing back to your standards. That should force the driver to be reloaded. Sometimes all you can do is reset the printer. To do this,, turn off printer, unplug both power and data cables, wait a few minutes, then reconnect and turn on again.
But search the online database for more specific instructions for your model.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 15, 2009 | HP Photosmart 3310 All-In-One InkJet...
Paper size error when copying - Office jet 7210
I got the same error, and had it for months. open the ink door where it says office jet pro, it folds towards you, wait for the ink cartage to position to the left, then look inside and far to the right, and see if there is a wadded up peace of paper inside. Reach in and pull it out, it fixes the problem
Dec 06, 2008 | HP Officejet 7210 All-In-One InkJet...
Have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Dec 21, 2007 | Office Equipment & Supplies
Problem printing
I work with printers all the time but I found restoring the factory defaults will solve 95% of all printer problems
Nov 13, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Paper size detected is not supported when making a copy
When I saw that so many other people were also getting this error message, I thought sure there would be a solution posted by somebody before too long. Guess no one could figure it out!
The problem continued and was getting extremely irritating so I went and spent a couple of hours on HP's support site and finally figured out what to do, even though I never did find the exact error message we've all been getting.
Basically, the fix is to change the paper size default setting in the Copy Menu from Automatic to Letter. You do this by pressing Copy, then #6, select Letter (which is #2), and that will bring you back to the Copy Menu. Scroll down through all 10 selections until you get to the bottom which is Set New Defaults and select this.
I've tried making several copies and it has worked every time now...no error message in sight! However, if you're trying to make copies onto paper other than standard 8.5x11, you'll have to select that with each individual job since there will no longer be an "Automatic" detection.
Hope this helps everyone else who has had this annoying problem!
Nov 07, 2007 | HP Photosmart 3210 Printer
HP Photosmart 3210 All-In-One InkJet Printer Logo
194 people viewed this question
Seeker5211
Seeker5211
