Plug my 320g Expansion on usb I see green lit but I dont see the drive on my com window
  • 6,831 Answers
Hello
Can you feel the drive spinning at the power up?
If the computer makes a sound, without notifying you that the device is not recognized, here is something you can try.
Go to:
Start
Control Panel
Administrative tools
Computer Management
Storage
Disc Management
Now you should see your drive in the schematic below, right click on it and choose to assign new drive letter and paths.If there is no drive letter assigned to the drive, assign on, otherwise just choose the option to change the drive letter.
Hope this can help you.
Kind regards
Andrea
Posted on Nov 17, 2009
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.em?
Sounds like driver problem to me. Re install the driver by using installation disc, or if you have lost your CD, than use this Driver Update Software to update. I hope this helped.
Brian
Oct 24, 2012 | Seagate Expansion 1 TB USB 2.0 Portable...
Drive does not start when plugged in. Says to format. Cannot get at data on drive. It is a segate 320g expansion drive
This has happened because you either
A) unplugged the drive without ejecting it properly first
B) experienced an electrical storm power surge with it plugged into your unprotected PC
C) Dropped, jarred, kicked, punched, or otherwise mishandled the drive.
It's a fairly common problem among people with these USB drives. One day it works fine, the next it's asking you to format. Unfortunately there is no way to get around this, a few (VERY few) people have said that plugging the drive into a different PC worked, but as far as I know your best bet is to format the drive and then immediately run a program like undelete to get your data back. It may or may not work, however, so you may have to consider this a loss.
- If the drive is still under warranty, get your money back.
May 12, 2011 | Office Equipment & Supplies
I purchased a seagate expansion 1tb in 3.5". initially when i plugged it into an usb port,(LED lit) it doesn't recognized by my Vista home premium 64-bit. i plugged it and waited for several...
> I purchased
Brand-new, I presume?
> is it a failed HDD
Yes. Take it back to where you purchased it, and get them to replace it, under warranty.
> software problem
No. It shows-up in "disk-management" as a recognized, but not-yet-initialized, device.
Thus, all the software to support it has been correctly loaded.
Exercise the warranty.
Feb 17, 2011 | Seagate Expansion 1 TB USB 2.0 Portable...
When I plug my 320G WD Elements there is no WD icon on my windows or my computer window. thanks
Have you used this HDD before?, it this is the first time?
Sometimes you have to install the WD Smartware Software. In the case of the 320G, which are the first HDD released, The computer should detect them automatically.
Try with another USB port. Do not use a USB multiport because it won't power the HD.
If it doesn't work on your computer, try it on another one. This way you can discard the possibility that the HDD is damaged.
God BLess You!!!
Feb 14, 2011 | Western Digital Passport 320GB External...
Gateway 702GE desktop When i push the front botton to start it up,the fans start to turn and then stops with no operation. The small green led on the motherboard stays lit and green and the front start...
try removing all the cards from the expansion slots and remove the ram sticks. disconnect the drive cables from the board but dont touch the cpu or power connectors. Now hit the button. If nothing changes, probable board fault. If it now boots up and starts beeping ( which it will when no ram sticks installed) shut it down and reinstall each drive connector, ram stick and card one at a time booting between each item. when the faulty item is connected, the board will stop booting and you can replace that item. Many things can also cause this. Bad connections to ram sticks and video cards, damaged usb port connections, failed cpu's, failed psu's etc.. You may still have to take the machine to a professional repairer to have the problem diagnosed.
Nov 02, 2009 | Gateway 702GE PC Desktop
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
Lacie 320G external Hard drive Malfunction
you'll find that the external chassis is buggered, get a new one and put the hdd in the chassis and see if your info is still there, but it should still be there...
Apr 26, 2009 | LaCie (300966U) 1024 GB Hard Drive
My computer dosen't recognise that I have already inserted my portable imemory into g drive
hi there what type of computer are you using and what operating system windows xp or windows vista ? and did you go to the windows update website to get all of the current drivers and patches to recognize all new items being sold these days eg cameras usb drives and such did you try plugging into a different highspeed usb port ? are you using a usb expansion hub this gives you more usb ports for many things like printers and scanners and such . go to www.windowsupdate.com and get all avail updates for software and hardware ok good luck waiting on a fixya rating to see how this project went
Jul 20, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Gpx mp3 player downloads
i dont know the exact model. but there should be a usb cable that came with it. you should then plug the usb cable into the mp3 player and then plug it into the usb port on your computer. at which point on your computer it should have a popup notification recognizing a expansion drive. such as C: would be your hard drive and D: your cd/dvd rom. open the newly formed expansion drive and you can just copy the mp3's to the mp3 player.
Jun 15, 2008 | Audio Players & Recorders
15 people viewed this question
k24674
