Question about Craftsman Garden
Model 917.370752 rear bag rear propelled had to start. did tune up, cleaned carb......whats the deal?
2 Suggested Answers
SOURCE: 22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
Posted on Aug 05, 2010
Yard works mower wont start
check the fuel filter if not you need to clean your carburator
May 02, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
What are the steps to start mower.
I could not locate your exact model for a manual. This machine's manual is very similar. Please read the operating and "How To Start" instructions inside the manual. They can tell you better than I.
http://lawnandgarden.manualsonline.com/manuals/mfg/yardman/120874r.html?idRes=11171312
Sep 11, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
I have a Craftsman 625 series 22" self propelled rear bag gas lawn mower that shuts down after running for about 10 minutes. Sounds like it's out of gas yet it's not. Cleaned the air filter, the...
My name is Dane and I am going to try to help you solve your problem.
I believe that you have clogged jets/passages inside of your carburetor. This can happen when an engine gets little use, allowing the fuel in the system to get old and begin breaking down. If fuel is left in a Carb for more than a year, it can eventually turn into a jelly like consistency, and clog the fuel system. What I believe is happening in your case is that the float needle inside the Carb is not allowing gas to enter the carb fast enough to keep up with demand. That's why it will run for 10 minutes and then shut down. After it sits for a while, the float bowl slowly fills back up and it will run for 10 more minutes.
Now for the bad news. This is an extremely difficult carb to work on. It is all I can do to get these Carbs off an engine and back on again to clean them. They are tough because you have a big air filter housing and 2 long bolts with gaskets and then the carb itself and spacers, that you have to hold together as a unit and start the bolts holding the carb to the engine. If you are a good enough mechanic to do this, you will already know how to do it. If not, I honestly suggest you take it to a shop and let them clean it for you. A new Carb isn't all that expensive, so you may want to consider just letting them replace it instead of cleaning.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thank you! Dane
Dec 04, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Cleaned the float bowl which was dirty, blew out the jet, replaced old gas - still runs for 5 seconds and then quits.
You need to take the carb off and clean it out real good.i would suggest soaking it in mineral spirits and blowing it out with air.take a bread tie and strip it.then you can take the tie and clean the passage way,s in carb.if that don,t work try rebuilding or replacing carb.I hope this helps.Dale
Sep 12, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
22 In Craftsman Self propelled.Starts easy, runs good for about 15-20 mins. Starts missing and dies. Will start again in about 30 mins New spark plug/ air filter
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Aug 05, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
8 year old Eagle I Craftsman 6.5 starts and quits? Help!
it sounds like a gumed up carb strip the carb and clean out all the running jets with carb cleaner,,,dont go poking wire into the jets you will only distroy them,,,also check that the air cleaner is clear if its cloged up the engine cant breeth and wont rev up and it will be running very ritch as well,,,check you have good flow of fule from the fule tank,,,winter takes its toll on garden tools that are stood up most of the time
Jul 10, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Motor has to be cranked alot to start and then when you push up on the throttle for more power it runs just above an idle , and dosent rev up all the way
Your carb. might be out of adjustment. There is a rod and another rod with a spring on it going from the carb. 2 an arm on the side of the motor. With the motor running, push the arm a little towards the carb. If it revs up, its out of adjustment, if not, you have a dirty or bad carb. Clean or replace the carb. If that doesn't work, your keyway might be cut or broke. The keyway is what keeps the motor in time so everything works together. Like a timing chain or belt on a car. Good luck.
Jul 09, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
My 675 will fire up a start and will immediatly quit. i have cleaned the spark plug and put in new gas.
it's still getting bad gas. take off air filter, prime with fresh gas, use an old spray can, and keep spraying while running until all old gas is used up in the carb
Jun 26, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Garden Logo
119 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
