Question about Tomtom GO 510 GPS Receiver
Fully charged and working normally tomtom go switched off when car was parked. 3 hours later tried to switch on but unit dead. Help please.
Used straightened paperclip to press reset for 15 seconds. Access hole near connector strip.
Posted on Nov 18, 2009
Tom tom dead
Usually, the device will not switch on because the battery is low, or not charged. If this is the case, charge the battery (fully) first, then try it again.
If your battery is fully charged, and/or the device is still connected to a power source, and it still doesn't start up, try to do a hard "RESET" ... by inserting a pin (or a straightened out paper clip) into the reset hole at the bottom of the device, and pushing it in (gently). Then try to restart it again.
If that still won't start the device, either the software is "bad" or the hardware is "dead". You may wish to send it to TomTom for repair, or abandon it.
Mar 04, 2014 | Tomtom XL IQ Routes GPS Receiver
I recently purchased the tomtom 340S XL. Can it
Using cable data /charger port you can do charging both at system or in car under car charger option. those specifications placed in manual and normally lasts for 3 hours
Dec 16, 2009 | Tomtom XL 340S Car GPS Receiver
Nano dead. Will not turn on. It was fully charged.
It's broken. Google "iPod repairs" in your country and they might be able to replace it. Otherwise you can get an exchange unit from Apple. Take it to your nearest Authorised Apple Service Centre and they will get it exchanged in a couple of days. Unfortunately this might cost almost as much as a new one.
Nov 03, 2009 | Apple iPod nano
My tom tom sat nav keeps going off i have replaced the battery but it goes dead and the screen goes off even when it shows it is fully charged if i wait a short time and switch it back on it will work for...
Hello there:
This issue usually results from eitherr a bad battery connection
or a lose wire inside the unit
i would suggest to remove the battery and look at the pins that the battery touches and see if they are bent or loose and see if they are clean and not corroded and than try to reinstall the battery and see what happens if this still does not solve your problem than i would consult a authorized tomtom repair center and if you have a warranty i would use it
Sep 18, 2009 | Tomtom ONE GPS Receiver
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Tomtom won't switch on
just try to reset it, by using a small pin or small needle within 3 sec..
Apr 27, 2008 | Tomtom One Europe v2 GPS Receiver
Switch on problem
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 09, 2007 | Tomtom One Europe v2 GPS Receiver
710 unit wont switch on again?off. 4 hour latter tried to turn it on again but does not switch on. Battery is charged but still not switching on?
Found the reset switch on GO 4V00.710 - look underneath, where the unit docks - small button - need a paper clip to press
Also, reset switch is documented in the Quick Start Guide - see label 'F' in the 'Your TomTom GO' what's in the box.
Dec 09, 2007 | Tomtom GO 700 GPS Receiver
Re battery life??
the battery should last 3/4 hours without a charger.
I think tomtom are aware of a ton of units with faulty batteries / poor life span.
arrange for it to be returned asap.
Dec 04, 2007 | Tomtom One Europe v2 GPS Receiver
GPS Logo
128 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
