Question about Ovens
I have a Neff U1420 double oven and the hinges on the main oven do not close the door fully. I have read that it is possible to correct this problem by putting washers under the screw of the hinges but I am having difficulty separating the 2 halves of the door to get access to the hinges. There are 2 screws at the top of the door on the inside and 4 further screws which I assume hold the hinges in place. There is mention of 2 other screws accessible from the bottom of the door but i do not seem to have these. Any ideas as to how to access the hinges would be appreciated.
    Scholar:
  • 62 Answers
Hi.
If the door does not close properly then the fault is a faliure in the door hinge springs. Sorry but using washers will not cure the problem..
The only way is to replace the two door hinges. You may NOT need to replace the hinge backs.
If you would like to email me the full model number (numbers after U1420) then i can source the part numbers for you.
regards
Aardvark Repairs
aardvark.repairs.btinternet.com
Posted on Nov 18, 2009
How do you take the doors off Neff double oven
fully open door and lift up small metal stirrups on bottom of hinge then close door up to them grip door firmly and lift upwards ,there are videos on you tube for this also.
Feb 09, 2017 | Neff Ovens
I have had both door hinges replaced on the main oven of my Neff but the door still does not close properly. What is the next step?
I would have gone straight through Neff. If it can't be fixed, your'e supposed to get a new oven out of the deal.
Apr 29, 2012 | Neff U1461 Double circotherm plus Electric...
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
The door of the main oven does not close properly even though we replaced the hinges (which worked initially) only about 18months ago. It's a U1420 NOGB double oven
If ther is notjhing obstructing the door from closing poroperly, then it sounds to me like the hinges are the cause of the problem again.
Make sure there is nothing trapped at the bottrom of the door, and that the hinge/s are not loose.
If it is leaving a small gap at the top of the door, then I think your only option is to replace the hinges again, as there is no adjustment possible of the hinges.
Hope this assists you with your problem
Dec 03, 2009 | Neff Ovens
Oven door won't close fully.
The only satisfactory solution, is to replace both the oven door hinges,\ which is a fairly straightforward job to do.
Thanks
Nov 09, 2009 | Bosch Ovens
NEFF oven U1461 - The bottom oven door hinges do not have enough strength to hold the door fully closed. Can these be adjusted and is this something I could do myself?
If the door is a drop down door, then no adjustment is possible, the only solution is to replace both door hinges.
Thanks.
Nov 05, 2009 | Neff U1461 Double circotherm plus Electric...
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Oct 20, 2008 | Neff U1661 Double circotherm super...
Main oven door will not close properly. Is there any adjustment for it.
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
May 06, 2008 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
346 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
