Question about Sony Handycam DCR-HC30E Mini DV Digital Camcorder
Sony hc30e handycam
Camcorder records perfect picture but no sound. Will play back a previous recorded tape but with no sound
    Master:
  • 619 Answers
Front switch microphone need full slide up or down not in meddle.
Tape some defective not recording sound
Handy cam not defective .
Posted on Jan 10, 2008
6ya staff
SOURCE:
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Nov 11, 2010 | Sony DCR-HC30E MiniDV Camcorder
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Hey guys, I bought this a while ago but it has been in and out of the repairs since i first got it out of the box. I was sick for a few years so it just sat in the box. But now I would like to use it, but...
Hi
Does not sound encouraging....was the screen always 'black'?
Was that the original fault or something different?
Usually, if the screen blacks out and there is absolutely no picture even attempting to surface it may be the flat micro film connector between the screen and the camera.
Have you tried recording a new tape and then playing it on someone elses camera?
Have you capability to transfer a newly recorded tape from the Sony to your PC?
All this will do is help eliminate the problems e.g. if the tape plays normally on your PC or a friends camera then it is definitely the screen. If not, then could be a myriad of things wrong.
Regards
Nigel
Jun 22, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Sony Handycam Vision videoHi8 will record sound, but no picture.
It is known problem of bad ccd imager in camcorder and requires replacement of that part.
Sony will repair CCD-TRV318 Free of Cost in ccd imager problem.
Please click Sony CCD Imager Support for details.
Good luck.
Jan 27, 2009 | Sony Handycam CCD-TRV318 Camcorder
Panasonic Video Camera
Hmmm. Try cleaning the tape heads with a mini dv cassette cleaner and see what happens afterwards. I would also recommend playing the tapes on a different camera and if you get the same response, then your audio is gone forever, but I highly doubt that would be the case.
Apr 27, 2008 | Sony Handycam DCR-HC30E Mini DV Digital...
Camcorder recording troubles
Dear elfox33
Your camcorder has dirty/clogged video head problem. Please use Video Head Cleaning Cassette Video-8 type to clean it. Hope problem will be solved.
Mar 18, 2008 | Sony Handycam DCR-TRV250E Digital...
Multi-coloured vertical lines on LCD screen and view finder
Hello, there is a chance for the Sony recall. Please contact your nearest Authorized Sony Service. If you need more info please advice.
Mar 09, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Trouble recording to DV Tape
Hello, cleaning the head and the tape path with cleaning tape is a good idea. Try it! If the cleaning does not help the video head is damaged. If you need more info please advice.
Feb 16, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Open Questions:
See all Sony Handycam DCR-HC30E Mini DV Digital Camcorder Questions
Sony Handycam DCR-HC30E Mini DV Digital Camcorder Logo
159 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
