Question about Whirlpool Calypso GVW9959K Top Load Washer
After washer runs for a few minutes it stops and runs agains, stops and runs again with stop and start intervals getting shorter and never finishes cycle. Seems it's unable to spin continuously.
  • 31 Answers
There are usualy sensors for the spin so that the drum is balanced properly if one of the sensors is faulty it will not spin or if the wate is not draining aswell so check the owners manual to see if there are any tests for he sensors that can be run to give you a code for the fault
Posted on Nov 17, 2009
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Maytag Performa pav2300aww stops and starts
If it's stopping during a wash cycle, suspect the heater elemant not heating up and moving the controller on. See if it runs fine during a spin/drain cycle. If it is very slow on all programs, try the noise filter capacitor before condemning the controller.
May 18, 2012 | Washing Machines
Washer will start and then stop 5 seconds later. It will start again 2min later and stop 5 sec after that?
I have a front loading frigidaire washer which works fine. It starts and stops throughout the whole wash but gets the wash done. That is how it works.
Does your machine simply stop and not finish the wash? Or are you concerned about the length of time it takes to get the wash done?
Aug 12, 2011 | Frigidaire Washing Machines
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer starts, runs a few seconds and stops,does it over and over
Sound like the internal overload on the motor may be going out .Thsi is usuaklly due to bad or worn bearings. If you know anything abotu electricity,take a voltage reading at the motor whe it is in the run cycle(when it stops) If you stil have have the 110Volts to the motor then the motor is bad and need to be replaced.If you do not then you wil have to look elsewhere for the problem.
Dec 14, 2008 | Amana NAV5800A Top Load Washer
Code F 40
Hello homefolks
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Your washer starts to wash and code come up it stop then starts runs for a
few minutes then code comes up again and does this over and over
can't finish a load. Model # 2709
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works! Waiting for your reply!
Please remember to leave a rating when you are done!
thank You huuum
Sep 25, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
157 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
