Question about Brother IntelliFAX 2800 Laser Fax
In paper for copy always jams - Brother IntelliFAX 2800 Laser Fax
  • 75 Answers
Try cleaning the rubber roller with a damp cloth
Posted on Nov 18, 2009
Printer jam after first copy
  • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
  • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
If you need any technical help on printer then you can reach at here
Mar 08, 2013 | HP LaserJet 2300d Printer
Paper jam
  • Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  • 2Turn off the copy machine before pulling out the paper.
  • 3Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  • 4Check for any paper fragments and clean up any torn pieces.
  • 5Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  • 6Replace the cover and paper tray and turn the machine back on.
  • 7Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push
    see the diagram for copiers and let`s the way of paper for troubleshooting .
  • 12_19_2011_4_33_16_pm.jpgsincerely. Merry Christmas.
    ernesto cuadra
    managua, nicaragua. c.a
    Dec 19, 2011 | Office Equipment & Supplies
    Can not copy two sided.paper always jam
    Check for some obstruction in the paper path where the paper stops. There can also be paper cuts in some of the sensor arms that may be giving hesitation delys csusing the jams. Jam codes in service mode will also help isolate the problem to a more specific area.
    Jun 17, 2011 | Canon NP 6050 Copier
    Just copy file..always jam..messagge"papper jam
    Causes for paper jams in Printers are given below:
    * Dust or debris
    * Rotating drum problem
    * Toner or fuser complaint
    Dust or debris
    One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
    If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
    Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
    Feb 22, 2011 | Office Equipment & Supplies
    Work Center Pro 575 always gets paper jams
    If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
    See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
    Note: The power can be left ON when clearing a paper jam.
    Typical Causes of Document Jams
    Recommended Procedure
    The document is fed at an angle.
    Adjust the Document Guides to the edges of the
    document.
    The document paper is too thin or too thick.
    Make a duplicate using a copier and use the copy
    as the sending document.
    Document has tape or pieces of paper taped to it.
    Remove the tape or make a duplicate using a copier and use the copy as the sending document.
    The Control Panel Cover is not fully closed.
    Close the Control Panel Cover fully.
    The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
    Basic Troubleshooting
    1. Remove all documents from the Document Support.
    2. Open the Control Panel Cover.
    3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
    4. Close the Control Panel Cover.
    5. Verify the display has returned to the Standby Mode.
    Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
    Always paper jam
    there is so many reason for that
    where the jam when u try to copy 1 copy
    Apr 24, 2009 | Canon ImageRUNNER 3570 Copier/Printer
    My adf jams. It does not feed the paper through it is missing the exit slot and jamming on the scanner. Is my scanner light spposed to always be on when the clover is closed? Thanks Richard Earle
    Yes, the scanner light is normal always on, even if the cover is closed.
    Try cleaning the rollers with some water.
    Check if there is a piece of paper or staple or something else in the paper path.
    If still jamming you need an engineer to service your ADF.
    Please use the platen mode to make copies
    Good luck and please rate me, thanks.
    Jan 21, 2009 | Brother MFC-8840D All-In-One Laser Printer
    Jammed paper at the Sorter Unit
    Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
    Jun 06, 2008 | Canon NP 6050 Copier
    Jams EVERY TIME
    Where is the paper jamming? Out of the paper tray or under the drum or in the fixing unit? Did you make sure you have the paper tray set up to the correct paper size and orantation for the paper in the paper tray and dose it happen at any other time and where is it jamed up at. Need more info.
    Mar 14, 2008 | Sharp AL 1631 Copier
    Brother IntelliFAX 2800 Laser Fax Logo
    51 people viewed this question
    CheckitRight
    CheckitRight
    Ron Dufek
    Ron Dufek
    James Cagle
    James Cagle
