Question about Crosley Dryers
My dryer wont turn on - Crosley Dryers
  • mikelafferty Nov 17, 2009
    ok all of that stuff is ok so now what?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 17, 2009
  • Rylee Smith
    Rylee Smith Nov 17, 2009
    How did you check the voltage at igniter? Do you have a
    multi meter?
    What voltage reading are you getting on the heating element?
    I hope you have made sure that the wiring is not burnt or cut. Please tell me
    the model number of your Unit so that i can provide you with model specific
    information.
    I hope that you have checked all the probable causes.
    Thanks
    Rylee
Dryer heats up wont turn belt is fine
if you can't turn shaft by hand, motor sized or bearings(on both ends of shaft) shot.
Jul 08, 2012 | Kenmore Series 70 80 90 PN281798 Dryer...
It turns on but seems like the basket wont turn, sounds like it is just dragging but wont exactly start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 04, 2011 | Amana NDE7800AY Electric Dryer
The dryer in my trailor tub wont turn I have Heat but the tub wont spin.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Mar 08, 2011 | Dryers
Dryer wont turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 19, 2010 | KitchenAid KEHS01P Electric Dryer
Water container light wont go off and dryer wont start
heatman101
Jun 01, 2010 | Whirlpool LER4634J Electric Dryer
Wont turn drum
heatman101
May 17, 2010 | Dryers
Hi, dryer wont turn on. has power but wont do
heatman101
May 14, 2010 | Frigidaire FEQ332E Electric Dryer
Dryer wont turn on, I reset main breaker but the dryer still will not turn on and run
overheat thermostate is located inside the machine, there may be a serious fault with or short with the heating element,. Good Luck - the Yeti
May 17, 2009 | Dryers
Tub wont and start switch wont hold
Hi! msbjs
Sound like this could be a motor problem. Is there a lot of lint inside the dryer and around the motor?
InMrFixIt
Oct 30, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
27 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
