Question about Daewoo DTQ-20U4SC 20" TV
Daewoo DTQ-2027 my tv image is only horizontal keystone
  • mrusk Mar 26, 2008
    turned tv on and off. unplugged and replugged. tried changing channels.
Shcamatic diagram
Posted on Mar 24, 2008
Ply back number
Posted on Feb 07, 2008
6ya staff
SOURCE:
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
Keystone not working
Manual: http://www.mitsubishi-presentations.com/wp-content/files_mf/mitsubishi_manual_xd250ust.pdf
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
Image on an angle
check the lens mirror, my be some angle is broken.
Nov 08, 2013 | Dell 1510X Projector
How do I angle the projector at the side of a screen & get the screen view of it straight?
In projector menu you will find a setting called 'keystone correction'. Use horizontal and vertical keystone correction to correct the projected image.
Sep 24, 2011 | NEC MultiSync MT1030 Multimedia Projector
The whole projection is not square when projected onto the screen. How do we square it up?
if it looks like a trapezoid, you need to keystone it. you can either use the keystone buttons on the top panel or go into the menu under the image adjustments and select the keystone feature.
Jan 13, 2010 | InFocus LP640 Multimedia Projector
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
The image disappears on my tv screen. A horizontal line appears.
You need to check the horizontal IC for deffects, possibly and most likely there are dry joints on the legs of the Horizontal IC. Have all the legs on the IC soldered nicely, this shud sort out your problems as you say you hit the TV then works. Try this before replacing the IC
Apr 16, 2009 | Televison & Video
TILTED IMAGE
reset the settings to factory default.
Jan 26, 2009 | Eiki LC-SM4 Multimedia Projector
If there any way to get a properly aligned image when recording a document or some other rectangular subject that is not straight?
When the camera is at an angle to a business card, document, whiteboard, or other rectangular subject, one side of the subject in the recorded image may appear longer than the side opposite from it. This is called "keystoning," which is caused by the difference in distance from the camera lens to each side of the subject. The side of the subject that is closer to the camera looks longer and the side further from the camera looks shorter. Using the camera's Business Shot Mode automatically eliminates keystoning and gives a normal shape to rectangular subjects. Though the Business Shot Mode is able to eliminate the effects of moderate keystoning, certain conditions may make automatic keystone correction impossible. Also note that the maximum Business Shot Mode image size is 1600 x 1200 pixels. If you have the camera configured to record larger size images, recording with the Business Shot Mode will produce a 1600 x 1200 size image. When the camera is configured to record images smaller than 1600 x 1200 pixels, the Business Shot Mode will produce images in accordance with the currently specified image size.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Daewoo DTQ-20U4SC 20" TV Logo
132 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
