Question about Sony DAV-SB100 System
The centre speaking is cracking I have changed the cable and swoped the speaker and it's still the same
Rear and centre speakers are not working
Check the cables input, try to connect the cables on other inputs in the receiver, if it not works probably the speaker are not working, if it works the receiver inputs are damaged.
Jan 07, 2016 | Audio Players & Recorders
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
My Sony home theater video center speaker don't work.
Check the connections between the speaker input on the rear of the unit, and the cable to the speaker itself, ensuring there are no weak spots or cracks. Check to make sure the centre speaker is securely connected to the correct port/socket on the rear of the unit. Also check settings of the surround in the unit's setup option - and if the display shows speaker icons and the centre one is not illuminated, it is probably OFF, or the selected mode/function does not require that speaker. If this is the case, change the function using the unit's function (mode) button, either on the front, or via the remote. (some home theatre systems have multiple modes/functions, for example MOVIE, DYNAMIC, DTS, 2 CH stereo, etc.)
It is also a good idea to do a 5.1 surround test - some DVDs have this as a bonus setup feature, but you can do this with a normal audio source, such as from a DVD or a TV program. You should hear a sound from each of the speakers, and if the unit has a volume control or each speaker does, make sure these are set to a relatively equal audible level.
If after trying the above, you still get no sound from the centre speaker, it is possible either the speaker itself or the unit has a fault. If it is the former, consider replacing the speaker. If it is the latter, this could be expensive in terms of parts and labour - as service technicians charge an arm and a leg for repairs to the amplifier circuit in these units.
In any event, try the basic, simple steps above before considering any further action. It could just be a faulty speaker, a bad connection, an incorrect connection, or a mode/function setting is wrong, causing the speaker to be OFF.
Jun 28, 2011 | Televison & Video
My sony dav dz270 home theatre has no sound through centre and rear speaker
You must have changed the listing mode to stereo.In that mode only the left / right & subwoofer will work. Press the surround button and change it to any other mode .
Mar 14, 2011 | Sony DAV-DZ720 Theater System
M & S MC602 intercom system locked up
Mine does the exact same thing, except mine isn't set up to change stations from rooms..did you ever find a fix?
Aug 09, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
Audio function "Bypass" - problem
try to increse the volume centre channel level so that u could hear better vocals. or do one thing if u r connected with optical cable only. just connect single RCA cable from dvd players centre channel output to the TV input (Left/mono) so that u can only hear the center channel volume thru TV and all other from speakers even the LG is working..
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | LG LHT734 System
Alpine CDE-9880R INTERRUPT MESSAGE ON SCREEN
Yes after speaking to a alpine tech at their support centre it was due to on of the cables on the back of the stereo which is used to detect a blue tooth device was touching a earth connection so has to insulate the cable now all working ok.
Nov 07, 2008 | Alpine Car Audio & Video
Samsung HT-TX75 Home Theater
Check the speaker connections to the centre channel. Also sometimes the settings of the centre channel can be switched off. If the unit has a test tone system start it going and see if it sends one to the centre channel. If it ignores it then it might be switched off.
Oct 02, 2017 | Audio Players & Recorders
Sony DAV-SB100 System Logo
61 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
