Question about Ricoh Aficio SP C222SF All-In-One Laser Printer
How do i fix an upper misfed jam? - Ricoh Aficio SP C222SF All-In-One Laser Printer
Try removing the paper tray first, the top page will likely be rumpled in some way. Remove that page, return the paper tray, then open the front cover. If there is any paper obviously stuck in the machine, carefully remove it.
My machine does these a LOT, I think if you get the problem frequently you'll need to have the rollers replaced.
Posted on Apr 29, 2010
REMOVED PAPER JAM
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe one got knocked off?
Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Paper Jam J43
One of the switches under the toner cart is knocked off.
Aug 09, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Showing misfed paper @ U1 U2, paper jam out, but still showing misfed.Checked and all paper is out. How can this be reset? Thanks
in the machine can be a little fragment from a sheet of paper so watch careful it can be right on the sensor for registration please open all doors and close them again.
But for i to be able to help you more you will need to tell me what brand is the machine and which is the model
Jul 15, 2009 | Office Equipment & Supplies
MISFED INDICATOR LIGHT FLASHING
There is no code to run.
Did the paper come out as an entire sheet? Or was it torn? There is either a small piece of paper that remains in the machine, or you dislodged a paper switch in removing the jam.
Apr 23, 2009 | Sharp AL 1631 Copier
Misfed document feeder
just check properly all document feeder may bi there is a piece of paper in feeder if not just check all sensors and levers .may bi some sensor is dirty clean all sensors in paper path and check all sensor levers .may bi some lever is jammed.mian jee
Jan 20, 2009 | Toshiba e-Studio 205 Copier
HP 1320 will not power up
There actually was a misfed sheet, hidden at the very bottom of the lower hinged back panel. The reason it was misfed was that this panel had somehow gone off one of its hinges. Ironically I did not discover the misfed sheet until I had taken the printer down from its shelf and turned it over to read the serial number to the extended warranty tech support guy.
Moral: Open every panel carefully, check for misalignment. These printers have flimsy plastic parts.
Dec 13, 2008 | HP LaserJet 1320 Printer
Paper jam in back top area of a konica minolta 2400w bob.crane@ihug.co.nz
moz-screenshot-7.jpgClearing Media misfeeds
To avoid damage, always remove misfed media gently, without tearing it. Any pieces of media left in the printer, whether large or small, can obstruct the media path and cause further misfeeds. Do not reload media that has misfed.
Note
The image is not fixed on the media before the fusing process. If you touch the printed surface, the toner may stick to your hands, so be careful not to touch the print face when removing the misfed media. Make sure not to spill any toner inside the printer.
Clearing Procedures
1. Pull the lever, and then open the top cover. If there is paper in the output tray, remove it, and then fold up the output tray before opening the top cover. Do not touch the transfer belt.
2. Slowly pull out the drum cartridge. removed drum cartridge on top of the printer keep it close and insure it is safe and stable where it sits. Be sure to keep the drum cartridge horizontal and place it where it will not become dirty.
Do not leave the drum cartridge removed for more than 15 minutes, and do not place the removed drum cartridge in a location where it would be exposed to direct light (such as sunlight).
3. Remove any misfed media.
4. Reinstall the drum cartridge
5. Carefully close the top cover
I hope this helps you and thanks for your question.
I the problem persists let Fixya know and we can detail a few items to check in order to determine the cause of the frequent misfeeds.....thanks........Whytfang
Aug 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Panasonic printer dp4520 error code j40
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Jun 07, 2008 | Office Equipment & Supplies
Misfed jams
First off, does the wheel indicate the proper size paper. Be sure to place close attention to the icon. Second, when you slide the drawer out, in the middle of the right edge, there is a spring loaded pad. Carefully peel the cork off, and rotate it 180 degrees, or you could switch it with the other drawer. Other than that, there might be a small wedge of paper in the lower switch, located in the middle of the paper path, between the paper guides. It may be next to impossible to see unless it is taken apart.
Feb 21, 2008 | Lanier 5222/27 Laser Printer
Paper Jam
hi im jules_09.have you reassemble the fuser correctly?check again the inside of the machine for small pieces of paper its just there the machine wont flash the misfed if there is nothing stock in the machine.although sometimes the drum can cause the misfed,try to full out the drum.it cant be stock just see if the drum is rotating try to rotate it 360 then slowly full it out,also check if there are srews where the drum process unit is at
Oct 12, 2007 | Toshiba E-STUDIO 650 Copier
Ricoh Aficio SP C222SF All-In-One Laser Printer Logo
134 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
