Question about Dell Latitude C610 Notebook
I cannot find a driver for wireless (network controller)
my windows crashed, reinstalled it, but now my wireless doesnt work anymore. I dont have a driver cd anymore.
the device instance id is: PCIVEN_14E4&DEV_4320&SUBSYS_00031028&REV_03&1472819D&0&18F0
I tried to download it on the dell site without result.
    Brigadier General:
  • 4,044 Answers
You may need to do a clean install. It is possible the crash was caused by the wireless faulting out. If you have the time, create a recovery disk and locate your restore partition. This is normally D: drive. Do a format and restore the system to original factory settings using the restore disk you create and the restore partition. If you can't create these your only other option is to purchase a full version of Windows and do a clean install using that. Make sure you choose to format the hard Drive C: as it is possible that your drivers are stored on any other drives on your computer.
Posted on Nov 17, 2009
When the wireless button is pushed the system crashes and will continue to crash unless the button is pushed off.
uninstall the wireless software that came installed with your laptop. and if needed reinstall it again. windows will run your wireless conection manager just fine, so find out what the name of it is, goto control panel and add remove programmes , remove the software for the wireless managment and restart laptop see how you get on then.
Nov 28, 2009 | HP Pavilion dv1060us (PM059UA) PC Notebook
Wireless driver uninstalls itself after restarts
if it's a usb-dongle, the driver's will be reinstalled every time you reconnect the device. the drivers are on your computer, but have to reconnect with the network adapter when it's reconnected. if the problem is the same after a reboot without disconnecting the network adapter, then there is either a problem with the usb-device, or a driver management problem in windows.
if the usb-device works without problem on another computer, the you need to reinstall windows.
Oct 05, 2009 | Buffalo Technology AirStation...
Wireless Not working
I thnk i have you in for a treat.. here is a site that hosts the drivers you need...
http://www.gzrcw.net/drivers/toshiba/Tecra/drivers_1199.html
if that doesnt work i found the name of the driver so that you could continue the search..
tm1wlanx
Good Luck... pls dont forget to rate me..
Jun 22, 2009 | Toshiba Tecra M1 PC Laptops
Cant connect to my wireless network anymore???
NVIDIA nForce Networking Controller drivers may have messed up your network drivers , since your network card is broadcom or intel pro, and it is not there.
Try reinstalling the wireless lan drivers.
You can download the wireless network card driver from link below:
Select software and drivers
In there you find different wireless drivers, download and install them all, the computer will automatically chose the correct ones.
You will have to enter your wireless network key again after reinstalling drivers.
Feb 18, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Medion mim2120 Wireless Problems
I had similar problem with Medion WIN 2140. The harddrive crashed, I bought a new drive and had to reinstall Windows from scratch since I had neither a backup or burned the reinstallation CD's. First I installed Windows7 and every driver/application/BIOS available from Medion's download site. At first my WIFI worked OK but somtime during the process og BIOS/driverupdate my WIFI antenna turned off. The antenna can be turned on/off with a easy access button (touchpad to the right of powerbutton) but WIFI button dows not work.
Medion's danish supporters told me that Windows7 is unsupported. So I had to reinstall using Vista. Still not able to turn on WIFI. I'm pretty sure that BIOS prior to version 1.0K (dated 06.01.2010) had a "ON" possibility but is now limited to "OFF" og "LAST STATE".
Medion support wouldn't og couldn't provide me a previous version of the BIOS. In fact Medion DK's support doesn't seem to know anything about their products.
However I have found the solution myself. Launch Manager application is needed for Easy Access buttons to work. Current version 1.5.0.5 of the application is faulty. In registry i found that pressed keys call the file fn.exe, this file is not a part of the OS, Launch Manager or any other Medion driver/application.
I googled for and found the prevoius version 1.4.9 of Launch Manager. This version works without any problems on both Vista and Windows7.
http://www1.medion.de/downloads/?op=search&lang=au&type=TEXT&Param=
I wrote to Medion support to replace the faulty application on their support site. But with my current Medion experience i daught they will do anything about it. So instead I post this reply to help others.
Oct 15, 2008 | Computers & Internet
Wireless driver not visble under network adapter setting.
yeppers..go to control panel, and work the wireless wizard
Mar 20, 2008 | Toshiba Satellite M55-S3512 Notebook
IT DOESNT WORK OUT
Sounds like your wireless is disabled.
If your using windows xp, check the following.
Go to your start menu
go to your control panel (might be under settings, might not.)
from control panel, if it says "Choose a Category" click switch to classic view.
open your Network Connections Icon.
If "Wireless Network Connection" is grayed out, right click it and choose, "Enable."
In Windows Vista
Go to the bottom right hand corner of your screen to the icons.
Right click on the double monitors (network connection)
Select Network and Sharing Center
Click on Open Network Connections
If "Wireless Network Connections:" is grayed out, right click it and choose, "Enable."
If it is enabled, and you already have wireless built in to your laptop, then it's possible the wrong wireless card is enabled. If this is the case, when you open your network connections, you will have two Wireless Network Connection Icons.
A Wireless Network Connection, and a Wireless Network Connection 2. Make sure 2 is enabled, and the first one without a number is disabled.
Let me know if this helps.
Mar 17, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Can not connect
It is possible that your windows update messed up the Linksys drivers. If your pc is xp, download the latest drivers from www.linksys.com/download. uninstall the wpc54g on the add/remove programs.
if using XP, reinstall drivers only, no need to install the linksys software. This would be best if you install the drivers manually. After this you will be using only the WINDOWS UTILITY for your wireless connection.
Feb 27, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Dell Latitude C610 Notebook Logo
250 people viewed this question
Alun Cox
