PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Random hanging and unit shutdown typ...
By villooc on Jan 10, 2008
My SONY VAIO PCG-FXA49 occasionally randomly hangs or shuts down typically after few hours (2-12 Hrs) of operation. The fan seems to be working normally as it can be heard switching on and off every couple of minutes.
Best Solution
posted on Jan 15, 2008
Helpful)
welshnproud
Rank: Master
Rating: 87%, 20 votes
Firstly please disregard first answer and the second is on the right line but I,m sure you will find the problem to be a software issue not a ram or hdd problem as these will present themselves at the start, not 2hrs or more later.( will contradict myself later)
firstly run a complete virus scan and any other programs you have associated with this.
If this comes back clean then as second answer suggests run a Chkdisk or scandisk.
If your confident enough to strip down the laptop and expose the cpu & fan then it may well help if you clean this and apply some compound to the heatsink as this will help cool the cpu as this may well be the problem, despite what I said at the start..hope this will help
Was this helpful?
Yes
No
Solution #2
posted on Jan 11, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
its mainly u r motherboard problem so kindly replace u r mother board...or check u r RAM,HDD, or Use some other HDD or RAM inthe same machine if same problem will occur mptherboard rplace ment is the only way..
Solution #3
posted on Jan 12, 2008
Not Rated)
ravs
Rank: Wiz
Rating: 83%, 213 votes
hi, mother board bad will be absolutly the last option,i have solved a similar problem again with a sony VAIO, the HDD stops after some times, this is when the system hangs up, or u have this FATAL error messages on the blue screen,RAM can also not be ignored, as sometiems it can also cause the same problem, see what u can go in for first , RAM Or HDD,Ii suggest u check the hdd, while the system is on try running the CHKDSK or scandisk, or any other disk checking utility,ur HDD might not be fully damaged , it might also have some BAD sectors.. good luck buddy.. let me know..
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
when i used the camera automatic stopped. what is the cause of this problem in my built in camera.
Answer
I have a HP dv9000 and I forgot my password. It keeps asking for it when I turn it on or reboot.i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
