Question about Microsoft Wireless Optical Mouse
I followed the instructions for set up i pushed the pin on the mouse then the pin on the keyboard then pressed the button on the reciever the mouse works fine but nothing from the keyboard
I need to know how to set up my mouse
Posted on Mar 01, 2010
Logitech wireless mouse (m305) isn't working
Does this mouse need to sync with the reciever plugged into the computer?
Somewhere on the mouse and posssibly on the reciever plugged into the USB
port on the computer it should have a connect button. Usually to connect/sync
a mouse or keyboard press the button on the reciever first then press the connect
button on the mouse. Or if th mouse has a button just press the mouse button,
often the mouses lazer will blink until the mouse connects with the reciever then
just stay lit at this point it sould work. Another Question, how are the batteries in
the mouse?
May 19, 2011 | Logitech Cordless Mouse
My cordless mouse quit working.
There are several different methods in resolving this issue. Before you perform these methods, make sure that the battery of your cordless mouse is fresh. Then, try this first method..
Method 1: Resynchronize your device with the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or the keyboard with the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put any other wireless keyboards and mouse at least 6 feet away.
  1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
    Note Some newer Microsoft devices are permanently bound to their receiver and cannot be reset. If your device does not have a button, skip to Method 2.
  2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
  3. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
  4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
  5. For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
The following example shows the buttons to push to synchronize a wireless hardware device
Method 2: Install the latest software loadTOCNode(2, 'moreinformation'); Download and install the latest Microsoft IntelliPoint and/or IntelliType software. For more information, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/download/download.aspx?category I hope these works for you. Should you need the other methods, kindly reply for follow up. Good Luck! Mongkey "Understanding explains better..."
Jan 24, 2011 | Logitech Cordless Mouse
The key board has lost its connection, please help. we hve tryed new batterys. the mouse still works.
mcdevito75 here, Sounds like you"ve lost the connection between your keyboard and reciever, that little angled piece with a button you press and lights up. First double check connection on your computer for this reciever, Then double check intsatlation of batteries in keyboard. NOW, press button on reciever, now press button under mouse and wait 20 seconds now press button on reciever then press button under keyboard. This should do it.
Jul 27, 2010 | Logitech Cordless Desktop MX 3000...
Dell studio one wireless keyboard not working
this issue w hat u have is common with dell studio what u need to do is synchronize the keyboard and mouse again . u can do it in the following manner :- 1] press the button on the side of the studio 1 its known as reciever 2]then press the button on underneath the mouse and the keyboard then agfain press the button on the reciever this needs to be done within 5 sec if its done properly u can use the keyboard an mouse /.
Nov 04, 2009 | Dell Computers & Internet
Keyboard went dead.
Man, I pushed the channel button and held it down. Turns out that doubles as the re-link button. So, basicly press the link button on the reciever, then press and HOLD the CH button on the back under one of those little footy things.
Oct 23, 2009 | Micro Innovations Wireless...
Keyboard and mouse not working
Make sure you have fresh batteries...usually this is how to set up a wireless keyboard and mouse. Insert the reciever in the USB and hit the link button normally located as a recessed button on the bottom, a light will blink....On the keyboard press the button as before located as a recessed button on the bottom. Once linked the reciever light should stop blinking...do the same with the mouse.
Jul 13, 2009 | Micro Innovations Wireless...
Mouse is recognised but key board is not.
Normal 0 Press the Receiver button (and the lights will start flashing.
Turn the Keyboard over and press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver. Should work okay then.
Hope this helps. Bud
Feb 18, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
I have a wireless mouse and keyboard, it stopped working, I changed batteries and tried to follow instructions on how to reconnect. I got to step one, pressed ctrl.alt and F12 it went to step 2 when I...
Normal 0 Normal 0 Press the Receiver button (and the lights will start flashing.
Then if it’s the Keyboard that isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If it’s the MOUSE, push the small RESET/CONNECT button on the back of the mouse to connect. Then they should work okay. Hope this helps. Bud
Nov 25, 2008 | Logitech Cordless Desktop MX3200 Laser...
Thing just won't work.
After starting up the computer with the wireless receiver, keyboard and mouse attached,, (with good batteries in both) install the CD software program and thenif it doesn't work follow these instructions:
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
May 11, 2008 | Microsoft Wireless Optical Desktop 1000...
Can not get mouse to move and buttons will not work on keyboard. batteries are all good
Dec 12, 2007 | Microsoft Optical Desktop 1000 (BV3000003)
Microsoft Wireless Optical Mouse Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
