Question about Car Audio & Video
When i turn on power fuse keeps blowing - Car Audio & Video
    President:
  • 1,114 Answers
If you still have speakers connected to it, disconnect them at the amp/receiver then power up. If the fuse still blows, you have a bad power supply or transformer and it needs service. If it stays on, check speakers and wiring for shorts by using a meter and checking continuity on wires and resistance on speakers. If your not familiar as to how to do this, go to any home audio shop and they will test them for you, usually free of charge and it only takes a couple minutes. Hope this helps
Posted on Nov 17, 2009
Brack lights wont light up on my 1988 ford ranger we keep blowing fuse and put in new brake switch
If you keep blowing the brake fuse than you have a short in the system. Unplug the brake switch. Install a new fuse. If it did not blow than the problem is after the brake switch. Next unplug the turn signal switch, then plug the stop light switch back in and press the brake pedal. Did the fuse blow. If not than the wiring is good in between the two switches. With the turn signal switch disconnected use a jumper wire in between the light green wire (power from the brake switch) and the orange with light blue wire (power to the right brake lamp). If the fuse blows than there is a short in the right side brake circuit between the plug in and the rear socket assembly. If the fuse does not blow than jump from the light green wire to the Light green with orange wire (power to the left brake lamp). If the fuse blows than the problem is in the left hand brake wiring circuit.
Sep 04, 2013 | Cars & Trucks
Power Windows and Turn Signals Not Working - 15A Fuse keeps blowing
If a fuse keeps on blowing there is a short in the wireing to that circut, Your best bet is to take it into a auto electric shop to be check out,
Nov 28, 2012 | 2005 Subaru Impreza 2.5
Fuse keeps blowing up as power is turned on..help.
Greg, If the fuse keeps on blowing there is a problem with the internal amp. It was probaly caused buy a electrical power surge, Or a (********) up Sub patch cord,
Oct 04, 2012 | Athena AS-P4000 Subwoofer
1987 Chevy silverado gauge / idle fuse keeps blowing
The 20amp ga/idle fuse powers a hot fuel module which powers the oil pressure switch, the fuel pump relay, and the fuel gauge in the tank.
Any of the four components including the fuel pump can blow the fuse.
Jul 23, 2012 | Chevrolet Cars & Trucks
I have a TRC 458 cb.... it keeps blowing fuses
It may have been reversed polarity on turn on. This can short out the polarity diode and then cause fuses to blow. This is a protection circuit so do not keep trying new fuses as the reverse surge can go into the radio deeper and damage it beyond repair.
Feb 02, 2010 | Radio Shack Radio Communications
Ignition fuse keeps blowing when i turn the key
It MUST be the starter relay coil - or the power wire that feeds it. Likely a short in the relay coil (AKA starter selenoid).
Sep 15, 2009 | 2003 Saturn L-Series
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
Blows fuse when turned on
this is a normal behavior if one of the power supply transistors have blown. take the unit to an enlectronics repair. they can either change the transistors affected (usually more than one) or replace the power supply board.
May 29, 2009 | Sansui DTV3200 32" TV
No parking lights, fuse keeps blowing.
There is a ground not connected or a wire open that is causing it to blow
Mar 08, 2009 | 1999 Pontiac Montana
Nad 218 thx power amp keeps blowing ac plug fuse
Hi there. From memory they had bridge rectifier problems with them going short circuit. Check them first. Sometimes the toroidal transformer can go a shorted turn, in turn blowing primary fuses. try to soft start it whilst it is blowing fuses, Best bet is to make up a special lead that has a 60w light bulb wired in series with the mains power supply(or across the fuse holdwer that is blowing:). Limits the power in the circuit to ... well you guessed it 60 watts.
check em out and let me know.
regards
Graeme
Apr 27, 2008 | Audio Players & Recorders
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
