Question about GE Profile Harmony DPGT750EC Electric Dryer
Convert propane hook up for dryer back to gas
Used to be gas
  • 31 Answers
The oriface size for propane and natural gas is the same it only has to be changed if you will be useing butane it should hook up and work the same but the propane will have a stronger sulfer smell than natural gas always connsult you gas provider if you are concerned they usualy will send tech to inspect if youhave questions for your safety
Posted on Nov 17, 2009
  • 177 Answers
SOURCE: I am converting my gas
Most american dryers have the regulator built into the gas valve.
you will need to put he correct parts on the gas valve.
do you have another regulator on the gas line before the machine?
If you dont feel comfortable doing this conversion you should call your propane supplier and have them do it for you.
Posted on May 25, 2008
  • 9 Answers
SOURCE: converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
Posted on May 25, 2009
  • 10865 Answers
SOURCE: dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
Posted on May 27, 2009
SOURCE: samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
Posted on Jul 01, 2009
SOURCE: Convert Whirlpool dryer from propane to gas
I have a whirlpool dryer as propane and needed it converted to gas. I have the orifce -gas kit which consist of two parts. Which part do I use? Is it the one which screws in and mist hole is on the other end, or the other one it comes with that has the mist hole on the other side.
The one i placed was the later ( one with mist hole on the side)
Posted on Aug 02, 2009
Propane to nat. gas dryer
Good day,
Yes. Two reasons. The orifice that the gas comes out is a different size, and the regulator that determines gas pressure is disabled when using Propane, since propane has the regulator on the tank.
See here.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
If you are not 100% sure what your doing, call a qualified company to perform the conversion. Isn't worth the gamble.
Propane is, unlike natural gas, heavier than air. It can pool in a low spot then ............
Dec 25, 2009 | Whirlpool GGW9200L Gas Dryer
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Jun 08, 2009 | Whirlpool GGX9868J Gas Dryer
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
You must purchase a conversion kit from your appliance parts store.
Mar 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Samsung gas dryer convert to propane
Mar 18, 2009 | Samsung DV448AGE Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
GE Gas dryer getting too hot
The gas burner valve is not the correct one for LP gas. You have to convert the valve as well as the orifices. The clicking is because it is over heating and cycling on and off o the high limit (safety thermostat)
Dec 18, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
I am converting my gas dryer to propane and would like to know if I have to remove the natural gas regulator before hooking up to LP gas?
May 25, 2008 | Dryers
GE Profile Harmony DPGT750EC Electric Dryer Logo
243 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
